2750D snowblower
/ 2750D snowblower #1
whatever1
Earth
I have two questions please.....
1 what oil goes into the gearbox
2 does the replacement scrapper bar have a bevel or is it just a piece of flat stock ?
/ 2750D snowblower #2
1. 80-90.
2. No bevel, just holes drilled to accept the bolts. Get the bolts as the heads will be half worn off on the old ones if you've let it wear down a lot.
/ 2750D snowblower #3
Best to get a gear oil with an extreme pressure additive. It will say gear oil and extreme pressure on the container.
The extreme pressure additive handles high load contact between two gear faces. Often it is a sulfur compound.
The only caution is if you have a worm gearbox which will likely have one gear made of brass or bronze. The sulfur will attack these metals
Worm gear boxes are found on walk behind snow blowers and on front mount small tractor blowers.
Dave M7040
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
iDrive TDS-2010H...
2021 Hitachi ZW150 Wheel Loader (A61166)
2021 Hitachi ZW150...
2016 Jeep Renegade 4x4 SUV (A61569)
2016 Jeep Renegade...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
UNUSED CFG INDUSTRIAL QK16R MINI EXCAVATOR (A62130)
UNUSED CFG...
