275 Gallon Home Heating Oil Tank-What should I do with it?
   / 275 Gallon Home Heating Oil Tank-What should I do with it? #11
I made a Maple syrup evaporator out of one.
My neighbor made one like that. probably the best use of an old tank I've seen, if you are in Sugar Maple country.
   / 275 Gallon Home Heating Oil Tank-What should I do with it? #12
What shape tank is it? Any idea of the wall thickness? I also thinking of a paint booth convertible to an oven for baking paint finishes. I would create a downdraft for the fumes and line it with disposable material that I would discard when changing over to paint booth. I would add casters so I can wheel it around for storage.
   / 275 Gallon Home Heating Oil Tank-What should I do with it? #14
nobody suggest a smoker. Lay the tank o is side and cut in half lenghtwise. add some grates a set of wheels and a burner and cook some great bbq.
Set each half about a ft. apart in your yard kinda like the Cialis commercials.
   / 275 Gallon Home Heating Oil Tank-What should I do with it? #17
I’ve got one too, original plan was a smoker, then I got a sweet Grilla pellet smoker and I like it so much that I can’t see myself using another unless I had a huge party. (Not likely at all)
I’ll make a dump trailer out of it eventually.
   / 275 Gallon Home Heating Oil Tank-What should I do with it? #18
WE had a smaller one, cut open one side and made a 'burn barrel' out of it.
Around here open fires burn underground and come out wherever later on so barrel burning is the safe way to go.
   / 275 Gallon Home Heating Oil Tank-What should I do with it? #19
Just because it is a 250 gallon tank, you don't have to put 250 gallons in it.
Just throw 50 gals in and monitor how long it takes to use it.
IF you heat with oil and your tank is outside, then you really don't need this tank as long as you can get your tractor beside it.
Be careful, could get condensation.
That's crazy! What do you mean by that? Like old coal mine fires burn and travel underground?
1111-A (A54756)
1111-A (A54756)
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
New/Unused Agrotk Tire Changer (A54865)
New/Unused Agrotk...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
