2720,moving 62d with 3pt, problem
/ 2720,moving 62d with 3pt, problem #1
lwalsh
Rockford MI
I found a nice used 62d for my new 2720 last fall. One of the reasons was I wanted the older model was for the brackets so I could move the deck with my 3pt and I-match. The problem is the 3pt dosen't drop far enough. About 3/4" shy of being able to drive under the pins. Is this a common problem? Am I missing something? I store it on a pallet so that is not a problem but when I take it off the tractor I have to use a spot in the yard where the front of the tractor is uphill so I can get under it with the hitch.
/ 2720,moving 62d with 3pt, problem #2
I have a 2520 with an older 62D deck as well (early 06) and yes I also have this problem. There are only a few spots where i can set it down so i can get under it with the Imatch.
Thanks goldenwings.
/ 2720,moving 62d with 3pt, problem #4
I don't know about the 2720, but on the 4300 you can thread out the 3pt hitch link on both sides to let it go down farther. the left side you have to take the pin out that holds the lift arm to the lower link arm. The right side is easlily adjustable.
2720 is one side only
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2024 JOHN DEERE...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
2022 EZ-GO ELITE...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Anthem...
