2720-2032r and 46 backhoe. How hard to install/remove?
   / 2720-2032r and 46 backhoe. How hard to install/remove? #1
jgss2
Connellsville PA
none
Just as the title says. I'm in the market for a Tractor/Loader/Hoe/MMM setup. I am considering several tractors and am now after driving one, really liking the 2 series tractors. My question is how much is involved to switch from a MMM mowing setup to the 46 Backhoe and vice-versa. I know it's not as simple as the 1 series but was wondering how much hassle is involved. Thank you in advance for any help. Buying your first tractor and set-up is nerve racking for a city-slicker who's moving to the country.:)
   / 2720-2032r and 46 backhoe. How hard to install/remove? #2
The 46 BH isn't too bad after you do it a couple times. I take mine off and on several times a year and it takes me about 5 minutes to take it off and 15 to put it back on. The tricky part is aligning just right and not letting it shift sideways when you lift the BH by the stabilizers. Slow and easy during this stage is very important. Good luck with the purchase. T
   / 2720-2032r and 46 backhoe. How hard to install/remove? #3
jgss2,
A MMM sharing space on a 2720 with the 46 hoe is the Achilles heel of the 2520/2720.
46 Backhoe - mid-mount mower interference - 2520, 4115
Consider a dedicated mowing tractor instead of the MMM. The cost is close to the same.
Or, look into the 270A backhoe instead of the 46.
   / 2720-2032r and 46 backhoe. How hard to install/remove? #5
I'm now buying a 2032r. Unfortunately the 270 will not fit the 2720/2032r tractors!
Yes, it's a bummer. I know the 270A fits the 2320 but I could swear I saw someone on another forum who had one on a 2032r.
If you are buying the 2032, what route did you decide to go? Mower/hoe, etc.
Nice machine, congratulations jgss2.
Thanks!!
Here's what I got....
2032r w I match and engine block heater
62d mid mower with kit to lock up mower link arms when not in use
H130 loader with 61 inch bucket
655 tiller
Frontier 2067 spreader
R4s (not loaded for now)
Ballast box
   / 2720-2032r and 46 backhoe. How hard to install/remove? #7
Very nice! I just ordered my 2032r with filled R4s, 46 backhoe, and 655 tiller. Dealer tells me they arrived yesterday and should be delivered next week. I am trading up from a 2320.
Matthew
2018 FORD F-150 (A53843)
2018 FORD F-150...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
