2710 (different) Steering Problem
/ 2710 (different) Steering Problem #1
PRSPlayer39
Hi Folks,
I'm hoping someone can help. I have a steering problem with my 2000 B2710 (780 hours). I've read most of the 2710/2910 steering problem posts, but mine is a bit different.
The tractor turns to the left with one finger. Turning to the right is very, very hard. It does it all the time, not just when hot. And it does it in any gear at any speed. I can use the FEL to lift the front end off the ground, and it's still one finger to go left, and the whole hand to make it go to the right (obviously easier with the wheels off the ground, but still much, much harder than left).
Fluids and filters were changed about 20 hours before this started happening. Fluids are still crystal clear.
Any ideas?
Thanks in advance for your help, Mike
/ 2710 (different) Steering Problem #2
I don't have drawings for your tractor, but I would say that you have a valve stuck in the steering unit.
Hey Jerry,
Thanks for the response. Is that typically a replacement exercise, or are there some ways to try and un-freeze it first?
Cheers, Mike
/ 2710 (different) Steering Problem #4
The valve and steering assembly is one unit. It is mounted below the steering wheel under dash. In Kubota's trouble shooting guide they mention nothing about steering not working in one direction. There may be something keeping valve working in only one direction. There is not much info in manual on how the assembly works.
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
John Deere Green Star 3 2630 Display (A64119)
John Deere Green...
2020 Hyundai Sonata Sedan. (A61574)
2020 Hyundai...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
