2710 backhoe control KMW14093088
/ 2710 backhoe control KMW14093088 #1
fyrewil
Fallon NV
Mahindra 2015 HST
Looking for a left hand control, for my 2710 backhoe, I have checked locally with in 250 miles, no luck. Looking for some bigger dealers that may have it in stock.
Back story, white plastic broke, went to disassemble control, set screw broke, attempted to drill it out, drill broke inside control....:mad::(
/ 2710 backhoe control KMW14093088 #2
If this is the plastic ball socket on end of control rod at the joy stick end, I have the same problem. I hope someone has come up with a solution.
/ 2710 backhoe control KMW14093088 #3
I'm not sure if the 2710 shares parts with the 3710, but I was over zealous when operating mine, and snapped the plastic inside. the replacement part was around $45.00. Try calling my dealer, Rogue Valley Farm Equipment, 541 826-8500
/ 2710 backhoe control KMW14093088 #4
Thanks AchingBack. I live in Remlap Alabama. Could you give me the proper name of this plastic part. I've been calling it a ball socket. When I call our dealer the guy I get is just a catalog technician.
/ 2710 backhoe control KMW14093088 #5
I will try to find out what it's called. If you call my dealer and explain the problem, they will know what you are referring to.
/ 2710 backhoe control KMW14093088 #6
I found my receipt for the part. It says, plastic rod connector. $41.00. However, the part number is different than yours.
/ 2710 backhoe control KMW14093088 #7
1409-3174 is the part number. We shipped 50 to Mahindra today.
