PBinWA
Platinum Member
- Joined
- Jun 10, 2004
- Messages
- 906
- Location
- WA
- Tractor
- Kioti NX55, Mahindra 2615, Case 36CXB, Case W4, Volvo MC85C
I've had my 2615 for 3 or 4 winters and even during the last really cold blast with it parked in probably the coldest place on my property (in front of my garage) it would always start reliably (not fast but it would start). I'm still on the original battery.
Here's what I do every winter:
1. I use Power Service Diesel fuel additive (the white bottle) starting in the fall and throughout the winter. I get it at Walmart or NAPA in my area. TSC may carry it. Make sure your fuel bowl has no water in it in the fall. If there is any water or cloudiness on the cold days then you need to clean out the bowl and put in a new filter. I've found Power Service will help with any water in the fuel lines.
2. Cycle the glow plugs three times before turning over the engine.
3. Let it run and warm up thoroughly. Then cycle the loader and 3pt lift repeatedly to purge the cold fluid.
4. Always park the loader curled up so the cylinders are fully retracted as much as possible.
I usually have to chip ice of the tractor while it is warming up and sweep snow off of everything. I was breaking ice off the grill and hood this last time just to keep it from getting too thick.
Also, if it's really cold I'll make sure I heat it up and run it at least once a day just to keep it "ready". That's why it's parked in front of my garage. I can fire it up and exercise the tractor after I exercise the dogs (they don't work so great in the cold weather anymore either).
