Oil & Fuel 2615 wont start HELP PLEASE!!
   / 2615 wont start HELP PLEASE!!
Thanks. First hand experience?
Ummmm. I will find out tomorrow.
   / 2615 wont start HELP PLEASE!! #14
I had a local mechanic come help and web bled the lines and have fuel with no air to the injectors. There is a solenoid the injector pump that is not moving. I think it is a fuel shutoff solenoid? Could this be the problem? It just clicks but won't move.
I'm confued by your last post.
If it's fuel shut off solenoid that is not working, the tractor won't start because there's no fuel available to the injector pump. How do you know the solenoid isn't opening? If it clicks that's usually a sign that it's opening. If it humms it's not. If the fuel shut off is not opening, how were you able to bleed the injectors?
Your original post said you were not able to get the rpm above pto speed and that's usually an indication of restricted fuel flow, not no fuel flow.
   / 2615 wont start HELP PLEASE!! #15
That was my understanding also...........Wonder what the OP found out?
The dealer replaced the pump on the right side of tractor. He said it is a mechanical pump of sorts. Tractor runs better now than it ever has. Thanks all.
Yes, that is the fuel shutoff but I sd told it only works after tractor warms up.
   / 2615 wont start HELP PLEASE!! #18
Glad to hear you got it working.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2277 (A58376)
2277 (A58376)
1986 VIM TACK TANKER TRAILER (A58214)
1986 VIM TACK...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
