3-Point Hitch 2615 with little up/down travel on 3 pt
   / 2615 with little up/down travel on 3 pt #1
azgreenb
Got a 2615HST 4x4 that we've owned since new. Only has 77 hours on it. The 3pt does not want to lift or lower more than a few inches. I've checked a couple of the threads regarding this and have had no luck.
I've sprayed everything down with penetrating oil. Adjusted the knob under the seat 3 pt speed. The 3pt lever itself wants to bind up near the top. At a loss and I want to till. HELP!
   / 2615 with little up/down travel on 3 pt #2
Get some penetrant soaking where the position linkage goes through the case.
I've sprayed everything in the following pic.
I will re-spray this morning.
Also there was a post where someone mentioned loosening the two nuts at the base of the 3pt lever. I did that and still no luck. :(
I took the lever off the main input this weekend. I found that the coupling where the (item 8 in the above pic) set screw is attached had become frozen/stuck. Sprayed even more penetrating oil and got it freed up.
Things still aren't 100% correct as I cannot install the (item 4) cover, without loosing full travel. So for the time being things are working well enough.
I was able to till the garden this weekend though.:thumbsup:
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
International 720 6-Bottom Plow (A52128)
International 720...
90018 (A48082)
90018 (A48082)
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
