3-Point Hitch 2615 with little up/down travel on 3 pt
   / 2615 with little up/down travel on 3 pt #1
azgreenb
Got a 2615HST 4x4 that we've owned since new. Only has 77 hours on it. The 3pt does not want to lift or lower more than a few inches. I've checked a couple of the threads regarding this and have had no luck.
I've sprayed everything down with penetrating oil. Adjusted the knob under the seat 3 pt speed. The 3pt lever itself wants to bind up near the top. At a loss and I want to till. HELP!
   / 2615 with little up/down travel on 3 pt #2
Get some penetrant soaking where the position linkage goes through the case.
I've sprayed everything in the following pic.
I will re-spray this morning.
Also there was a post where someone mentioned loosening the two nuts at the base of the 3pt lever. I did that and still no luck. :(
I took the lever off the main input this weekend. I found that the coupling where the (item 8 in the above pic) set screw is attached had become frozen/stuck. Sprayed even more penetrating oil and got it freed up.
Things still aren't 100% correct as I cannot install the (item 4) cover, without loosing full travel. So for the time being things are working well enough.
I was able to till the garden this weekend though.:thumbsup:
2011 JOHN DEERE 329DT SKID STEER (A51242)
2011 JOHN DEERE...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
