2615 Radiator Leaking, Replace/Repair
   / 2615 Radiator Leaking, Replace/Repair #1
ditzel
N.J.
Mahindra 2615 Gear
Yesterday I noticed antifreeze leaking from the radiator of my 2615. Been using tractor quite a bit last few weeks, leak just started yesterday. Looked around online, only 1 I could find was Bill's in texas, they want $800 bucks!. At other Mahindra dealers and a cub cadet dealer cause 7620 is the same tractor,the radiator is discontinued not available. Closest replacement I seen was a radiator for a 94 honda civic manual trans $65-$150, looks to be a close match, but would need some modification in order to securely mount it. So I decided to remove my radiator and dropped it off this morning at radiator repair shop.
Wondering if anybody has had to replace their radiator on 2615?
   / 2615 Radiator Leaking, Replace/Repair #2
Actually I was going to suggest seeking out a radiator repair shop. They may even be able to replace the radiator core.
Picked up my radiator from the repair shop on lunch break today. Put it back in the tractor after work and no leaks. In 1 day the shop had it in acid tank, repaired and repainted and ready for pickup, for a $100. I couldn't be happier with them.
UPDATE: The repair lasted about 6 months, removed it again, took to different rad shop, (a 1 man band) he removed top and bottom and replaced core with new for $450. I searched everywhere, unable to find a direct replacement, so replacing the core was only option.
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2024 Spartan KGZ-XD Zero Turn Mower (A50514)
2024 Spartan...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
2024 John Deere 872GP Articulated Motor Grader With GPS Package (A52143)
2024 John Deere...
