2615 Radiator Leaking, Replace/Repair
/ 2615 Radiator Leaking, Replace/Repair #1
ditzel
N.J.
Mahindra 2615 Gear
Yesterday I noticed antifreeze leaking from the radiator of my 2615. Been using tractor quite a bit last few weeks, leak just started yesterday. Looked around online, only 1 I could find was Bill's in texas, they want $800 bucks!. At other Mahindra dealers and a cub cadet dealer cause 7620 is the same tractor,the radiator is discontinued not available. Closest replacement I seen was a radiator for a 94 honda civic manual trans $65-$150, looks to be a close match, but would need some modification in order to securely mount it. So I decided to remove my radiator and dropped it off this morning at radiator repair shop.
Wondering if anybody has had to replace their radiator on 2615?
/ 2615 Radiator Leaking, Replace/Repair #2
Actually I was going to suggest seeking out a radiator repair shop. They may even be able to replace the radiator core.
Picked up my radiator from the repair shop on lunch break today. Put it back in the tractor after work and no leaks. In 1 day the shop had it in acid tank, repaired and repainted and ready for pickup, for a $100. I couldn't be happier with them.
UPDATE: The repair lasted about 6 months, removed it again, took to different rad shop, (a 1 man band) he removed top and bottom and replaced core with new for $450. I searched everywhere, unable to find a direct replacement, so replacing the core was only option.
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2012 CATERPILLAR 303.5E CR EXCAVTOR (A65056)
2012 CATERPILLAR...
PORTA POTTY (A68842)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
