3-Point Hitch 2615 lift issue
/ 2615 lift issue #1
booman
lexington,nc
Massey Ferguson 2615
I'm having lift probems on my 2615. sounds like the PTO is engauged when all the way up and the lift seems to bounce and if I press the cluth in the lift will drop. Please help
/ 2615 lift issue #2
I'll answer what I can since you have no replies yet. On most Masseys it is normal for the lift to drop when you push in the clutch because the pump only turns when the clutch is out. If you have a two stage clutch you can push the clutch half way in and shift gears without the arms dropping. Not sure what you mean by "sounds like PTO is engaged when all the way up".
/ 2615 lift issue #3
Isn't that a fairly new model? Does it have a FEL? My tractor had trouble with the three point hitch not lifting and was bouncing on the way up. Come to find out it was a problem with the relief valve on the loader itself.
/ 2615 lift issue #4
The lift should NOT drop when you depress the clutch.
MF shipped many (most?) 2600 series tractors tractors with lift issues. Take it back to your dealer for warranty repair.
SDT
