2615 hst stuck in reverse gear?
   / 2615 hst stuck in reverse gear? #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
I have a 2005 2615 hst with fel with 177 hours. I was working in the yard a couple of days this week and noticed that any time I pressed the reverse pedal then let off it the tractor still wanted to go backward unless I placed it in neutral or pushed down the forward pedal several times. When I say it kept going backward, I don't mean at full speed but very slowly. I was on level ground so gravity should not have been an issue. Does the pedal need to be adjusted or do I have bigger problems?
   / 2615 hst stuck in reverse gear? #2
There is an adjustment for that under your Rt foot rest.
What is the correct way to adjust the pedal?
   / 2615 hst stuck in reverse gear? #4
On my 2810 there is a spring going in each direction to pull the pedals back
into the neutral position..... I Started to have the same problem and then about a week later one of the springs broke and the pedal went to the floor !!.... I went down to the hardware store and bought two new heavy duty springs the same length and it has worked fine ever since.....
Dave in NH
   / 2615 hst stuck in reverse gear? #5
I have to go to a funeral today, and can't check till tomorrow, as I can't quite remember how to do it. I know if I take a look under the step on one ot the tractors, it will come back to me. I will check tomorrow and post it for you.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
(4) Rolls of Barb Wire (A50515)
(4) Rolls of Barb...
