2615 hst stuck in reverse gear?
   / 2615 hst stuck in reverse gear? #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
I have a 2005 2615 hst with fel with 177 hours. I was working in the yard a couple of days this week and noticed that any time I pressed the reverse pedal then let off it the tractor still wanted to go backward unless I placed it in neutral or pushed down the forward pedal several times. When I say it kept going backward, I don't mean at full speed but very slowly. I was on level ground so gravity should not have been an issue. Does the pedal need to be adjusted or do I have bigger problems?
   / 2615 hst stuck in reverse gear? #2
There is an adjustment for that under your Rt foot rest.
What is the correct way to adjust the pedal?
   / 2615 hst stuck in reverse gear? #4
On my 2810 there is a spring going in each direction to pull the pedals back
into the neutral position..... I Started to have the same problem and then about a week later one of the springs broke and the pedal went to the floor !!.... I went down to the hardware store and bought two new heavy duty springs the same length and it has worked fine ever since.....
Dave in NH
   / 2615 hst stuck in reverse gear? #5
I have to go to a funeral today, and can't check till tomorrow, as I can't quite remember how to do it. I know if I take a look under the step on one ot the tractors, it will come back to me. I will check tomorrow and post it for you.
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52128)
2023 Maxx-D TDX...
2004 CHEVROLET C5500 PASSENGER BUS (A51243)
2004 CHEVROLET...
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
