2615 hst - overheating when using pto
   / 2615 hst - overheating when using pto #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
Any time I use my bush hog or finishing mower the heat gauge needle gets almost into the overheat area. In other words, it is almost right on the line b/t normal and overheat. The tractor only has 28 hours on it. I normally mow in the middle gear and bush hog in the low gear at the suggested rpms on the tractor. My bush hog is 5 feet wide and my finishing mower is 6 feet wide. Do the 2615 models normally run toward the hot end? Any suggestions?
   / 2615 hst - overheating when using pto #2
They do not run hot. How clean is the radiator? It can clog up with fine debris in the fins in a matter of just an acre or two of mowing if the conditions are right.
   / 2615 hst - overheating when using pto #3
I have a mahindra 4500 6ft mower can run in 100 degree weather will not overheat at all, but as Dave mentioned you have to keep your radiator clean on any tractor.
   / 2615 hst - overheating when using pto #4
Mapp1
in front of the radiator there is a screen to protect it from grass seeds and debris, pull up on it and take it out .
Give it a gentle shake & all the problems will shake right off of it. /forums/images/graemlins/grin.gif Like Dave said its probably your screen.
Ernie
   / 2615 hst - overheating when using pto #5
I would bet that the front air intakes are clogging at speed. When you back off to idle the vacuum drops and the grass debris falls off and all seems well. My 7205 Cub does the same thing. You have to stop and clean those **** intake screens too often! Don't forget the one in front of the radiator too.....
   / 2615 hst - overheating when using pto #6
I've never seen my temp gauge go above about 1/2 way up the "normal" (green) range, even after brush cutting for a couple of hours. Maybe the gear models don't run quite as hot as the HST models, who knows? I do make a point to check the radiator screen (the removable one) anytime I get off the tractor.
BR
   / 2615 hst - overheating when using pto #7
Run your tractor a max rpm and drop you range to low and run with the full hst pedal for max speed.
   / 2615 hst - overheating when using pto #8
Thing is, I don't have a HST pedal. I have a 2615 4WD (gear). I thought that would have been clear when I said, </font><font color="blue" class="small">( Maybe the gear models don't run quite as hot as the HST models, who knows?)</font> Sorry for any confusion.
I have a KK BB60 boxblade coming this afternoon. I'll see if I can get my tractor hot using the bb.
Later,
BR
Where would the air intake screens be located? I know where the radiator screen is and I cleaned it because it was rather filthy.
Run it at max rpms or max rpms suggested for using the rear pto? Also, I am assuming if I do this then it will not run toward the hot end supposing I make sure the radiator screen is clean?
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
