Oil & Fuel 2615 fuel filter problems
/ 2615 fuel filter problems #1
Chesterpeake
Having problems with the fuel filter stopping up on my 2615. Began last spring--purchased the tractor after it sat on the lot for about a year--fuel filter promptly stopped up--dealer did not use treated fuel in the tractor--I emptied the fuel tank, installed new filter, and had the same problem about 3weeks later. I use treated fuel, and still need to change the filter every 8 or 10 hours. Anyone have any ideas? Am tempted to install a larger filter assembly. That being said, I really like the tractor.
/ 2615 fuel filter problems #2
What are you using to treat your diesel?
Perhaps you should just flush out that diesel and get some from a different place with a higher turn-over rate.
I like Power Service Diesel fuel additive in the white bottle. I get it at Walmart or NAPA but you may have to look elsewhere.
I've had my 2615 for almost 4 years and only had some clouding in my filter once. Power Service cleaned it out promptly.
/ 2615 fuel filter problems #3
This is why I say that I wouldn't buy a tractor that has been sitting unused on a dealer's lot for a year or more. Among other issues, who knows what could have gotten into the fuel tank in that length of time. Still, it sounds like you are doing the right things. You may need to do more than just emptying out the fuel tank however. You may need to have the fuel tank cleaned.
Rusty
/ 2615 fuel filter problems #4
Rusty
This was my thought as well.... the whole system needs a good flushing now.
/ 2615 fuel filter problems #5
The first question is what is plugging up your fuel filter? Is it bacteria (a black slimey residue), rust, dirt or something else. Next time you remove the filter examine it and see what is actually plugging it up. If it's a canister filter cut it open.
Yes, the residue is black and slimy. Not sure of the name, but I used a diesel fuel treatment from TSC. Emptied the contents of the tank last fall, but didn't flush.
/ 2615 fuel filter problems #7
You might want to get some of this:
Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economy
Bio Kleenョ Diesel Fuel Biocide
Microbes in the form of bacteria and fungus are present in all diesel fuels. Long periods of fuel storage can create ideal opportunities for microbes to grow in fuel tanks. The first indication of microbial contamination is mucous-like accumulations on fuel-filters and increased requirements for fuel-filter replacement. Microbes can only be removed from the fuel system by use of a diesel fuel biocide.
Hey Power Service, with all this free advertising can you send me some free product? ;)
Thanks, guys, for the feedback. Think I will drain and rinse the tank and get some kind of bacterial treatment.
/ 2615 fuel filter problems #9
Fortunately it is just a few bolts and a matter of minutes and you can have the tank off and then clean it real well. Chnage the filter again and your problem is solved. If the problem comes back, it is because it is being introduced by new fuel that is bad.
How do you store your tractor fuel? 5 gallons at a time, or in a barrel? It would be nice to find the source of the bad fuel.
/ 2615 fuel filter problems #10
When using a biocide the first time and it wouldn't hurt to do it a second time use what is called the Shock Treatment. It's usually a higher dose than is used as a regular maintenance treatment. The Shock Treatment should kill off all the little buggers. A good cleaning of the tank sure wouldn't hurt either. If you just treat the fuel and kill the colony of bacteria it will just die, dislodge and usually cause even worse filter plugging problems until they are all sucked through the fuel systems filtration system.
/ 2615 fuel filter problems #11
I just had a problem with bacteria in the fuel as well. After cleaning it and using the anti-bacterial, the other really important thing is to keep the moisture out. The bacteria can't grow without moisture.
/ 2615 fuel filter problems #12
I stopped by a truck repair center to pickup the treatment for bacteria and found out this is an extremely common problem. Apparently since the requirements for lower sulfur diesel have gone into effect, it makes it easier for bacteria to grow in diesel fuel.
Hensley 16in. Bucket with Teeth Excavator Attachment (A68183)
Hensley 16in...
FUEL TANK (A68842)
FUEL TANK (A68842)
****Power to dash w/jump pack. Does NOT start**** Year: 2012 Make: Ford Model: Transit Connect (A66738)
****Power to dash...
2020 Bobcat E26 Mini Excavator (A66734)
2020 Bobcat E26...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2007 KENWORTH W900 (INOPERABLE) (A67714)
2007 KENWORTH W900...
