2615 Air Filter Question
/ 2615 Air Filter Question #1
zippy215
Florida
Has anyone been able to cross reference the Air Filter for the 2615 tractor and/or know where I can purchase one without having to give up my first born???
/ 2615 Air Filter Question #2
kubota air filter
T0070-16323
Thanks for the information. It's gotta be cheaper than the Mahindra filter.
/ 2615 Air Filter Question #4
The best cross that I am aware of for the air filter element for a 2615 Mahindra is Baldwin PA3792. Probably even less expensive than the Kubota filter. Hope this helps.
/ 2615 Air Filter Question #5
Wix filters for Mahindra 2615
Air 46483
Fuel 33264
Hyd. 51663
Oil 51356
/ 2615 Air Filter Question #7
Will I void the warranty if I use those?:confused:
/ 2615 Air Filter Question #9
I'm scared to ask where you looked that up, but THANKS!!!:D
/ 2615 Air Filter Question #10
I think the problem would be if you used an aftermarket filter that you thought would interchange, yet it was actually different and that difference caused a problem. The Baldwin air filter above is about 1/8" longer than the Mitsu filter. I am sure it is very good quality, Baldwin stuff always is. But if for some reason it did not seal properly and allowed dirt to enter the engine, then you would have a warranty problem. Not because you used a different brand, but because it was not the correct filter for the application.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
(10) New CATERPILLAR Keys (A65579)
(10) New...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
378909 (A61166)
378909 (A61166)
