2615 Air Filter Question
/ 2615 Air Filter Question #1
zippy215
Florida
Has anyone been able to cross reference the Air Filter for the 2615 tractor and/or know where I can purchase one without having to give up my first born???
/ 2615 Air Filter Question #2
kubota air filter
T0070-16323
Thanks for the information. It's gotta be cheaper than the Mahindra filter.
/ 2615 Air Filter Question #4
The best cross that I am aware of for the air filter element for a 2615 Mahindra is Baldwin PA3792. Probably even less expensive than the Kubota filter. Hope this helps.
/ 2615 Air Filter Question #5
Wix filters for Mahindra 2615
Air 46483
Fuel 33264
Hyd. 51663
Oil 51356
/ 2615 Air Filter Question #7
Will I void the warranty if I use those?:confused:
/ 2615 Air Filter Question #9
I'm scared to ask where you looked that up, but THANKS!!!:D
/ 2615 Air Filter Question #10
I think the problem would be if you used an aftermarket filter that you thought would interchange, yet it was actually different and that difference caused a problem. The Baldwin air filter above is about 1/8" longer than the Mitsu filter. I am sure it is very good quality, Baldwin stuff always is. But if for some reason it did not seal properly and allowed dirt to enter the engine, then you would have a warranty problem. Not because you used a different brand, but because it was not the correct filter for the application.
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
70" Padfoot Shell Kit (A68134)
70" Padfoot Shell...
2005 (INOPERABLE) FREIGHTLINER COLUMBIA 120 (A67714)
2005 (INOPERABLE)...
CAT R450/D9H Ripper Teeth (8) (A68134)
CAT R450/D9H...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
