2610D Injector pump timing
/ 2610D Injector pump timing #1
rock2610D
Cheyenne WY
2610D
Trying to time my tractor correctly. With clear hose attached to #1 injector line I find that my pump timing must be off.
There are a total of 6 lines/marks on my crank pully. 3 of the lines/marks on my pully have #1,#2, and #3 right next to them. The other 3 lines are about 1 inch ahead of their corrisponding cylinder lines/marks, as engine is rotated clockwise.
When my fuel stops rising in the clear hose my tick mark is right between the mark that says #1 and the other unknown mark.
Which one is the mark I need to hit? The service manual I have states "TIMING MARKS". The photo is too dark to see.
The reason I am asking is because the tractor is VERY hard to start in cold weather IE below 60 deg F.
/ 2610D Injector pump timing #2
Rock,
I'm not familiar with all of the marks you've indicated for fuel pump timing.
I'm only aware of the two - Camshaft and Crank for #1 piston at TDC. Since you have the benefit of additional marks on your setup, can you watch each of the cam lobes that lift your injector pump rollers (with the timing case cover off of course)??
I would think that after every third revolution the cam lobe angle should be at the 12 o'clock position indicating the correct timing for that cylinder. And I'm not aware of anyway to actually change the pump timing... but changing the cracking pressures by adding or removing pump shims at the base of your pump.
Back to the original problem. I think a tractor that has difficulty starting at or below 60° is often a compression problem and not really pump timing.
I hope I'm wrong.
Mark
I agree it could be a compression problem, most of all because I live at 8000 feet of elevation.
I am just wanting the timing to be right on to help minimize the elevation issue. Basically, my air pressure is right around 11 psi as apposed to the 14.7 psi at sea level. Thats 3.7 psi lost due to elevation. 3.7 psi x 7.8 in^2 bore = 29 pounds lost. Basically, its like this. at sea level 14.7 X 21(COMP RATIO) = approx 310 psi compression at TDC.
I however only have 11X21=231 psi. at TDC!!!
My tractor needs to be in tip to shape to function at my elevation. That is why I want my timing dead on.
A turbo is in the works to compensate while running but I have no idea how to increase pressure while cranking!!
/ 2610D Injector pump timing #4
60 deg below 0 :eek: I wouldn't be outside in that weather. I would also look at the oil weight etc,.I don't know of a Dino oil that will even pour that temp.
I would be hard to start in that kind of weather:D
/ 2610D Injector pump timing #5
lol Kenmac, I think rock2610d meant below 60F.. :D
Rock, do you give it plent of throttle, and preheat with compression release? I believe Mark777 will be able to give the most advice on timing, but i never hear/read about others setting timing on these older yanmars... If anyone knows about that, please write in! I'd like to advance the timing on one of my yanmars to increase top-end HP capabilities... :)
/ 2610D Injector pump timing #6
Ok, my bad I re-read his post:p . I'm kinda tired & shouldn't be posting . Been up since 6am cutting very large trees & just came in
/ 2610D Injector pump timing #8
rock2610D said:
... but I have no idea how to increase pressure while cranking!!
When I bought my Yanmar it had a weak used battery and nasty old un-volatile fuel. And the ThermoStart was dead. In the middle of winter. Until I sorted out the fuel problem what I did to help start it was to set the 2-10-50 amp charger on the hood and overcharge it, 50 amps for a minute or so, then 10 amps for a few minutes, then a 50 amp boost while I cranked the starter. It spun like mad.:D You might try a similar approach, or get one of those 650 amp portable boosters to use during power outages.
I would be surprised if it is a timing problem. They can't get out of time unless someone tinkered with it. Where did you buy it?
According to my 336 manual you can adjust the point at which the injectors pop into the pre combustion chamber/cylinder. Adding shims will make them pop later and subtracting shims earlier.
I just do not know which mark to hit. The one that says #1 next to it or the other unknown one. At this point I spent the day experimenting.. I took out all the shims (3 total) and put back togather. All that did was move the pointer location a couple of degrees more advanced. There is NOWAY of hitting unknown line/mark with out grinding the face of the pump. WILL NOT DO THAT!!
Next I took a 1/16" intake gasket and added the 3 shims and pointer was now directly on the line that says #1. Tractor seems to start fine and it runs just as well as the previous setting. Its summer so all I can do now is wait for a 60 degree day.
I am also going to try hooking up the thermistor heater to the crank side of the ignition switch too. Plus I have found that NOT using the decompression lever works better. Because I have put the largest strongest battery I could find (1200 CCA) in the tractor and cleaned posts and ground points the tractor spins over nicely. Using the decompression lever only allows more cold air to get in the cylinders. I spin the motor over for about 10 seconds with fuel OFF to help heat cylinders (IE cold fuel not being injected) and then engage the throttle.
Since I put new injectors in its easy to check compression. That is on the list too.
Bought it from a dealer in Louisiana, who got it from an estate sale. Tractor has 1320 hours on it and I was told it started great in LA.. A friend of mine picked up the tractor for me and before he delivered it he used it a couple of times in Louisiana and he said it started great! Its warmer and air is denser there, go figure.
I am going to IL next November so I will probably tow the tractor there and see how it starts there in cold weather with dense air.
Well, I took Mark's advise and called a diesel specilist and told him my "Story". He said immediately that if its a Japaneese tractor made to run in Japan that Japan's diesel fuel is MUCH better than ours. And a tractor could be hard to start in the US Expecially at high elevation due to poor diesel. He suggested a double dose of Cetane improover and Premium Diesel if possible.
I was also told the it is very possible that the compression ratio for Japanese tractors is lower than ones made for U.S. diesel fuel. He said he would not be supprised to find 18:1 or even a little lower on tractors made for Japaneese Markets due to their GOOD diesel. That combined with high elevations and poor diesel WILL make a tractor hard to start in cold temps.
Here is a quote from an artical I read.
"Aromatic hydrocarbons have poor self-ignition qualities, so that diesel fuels containing a high fraction of aromatics tend to have low cetane numbers. Typical cetane values for straight run diesel are in the range of 50-55; those for highly aromatic diesel fuels are typically 40 to 45, and may be even lower. This produces more difficulty in cold starting, and increased combustion noise, HC, and NOx due to the increased ignition delay."
U.S. Diesel is highly aromatic. IE 40 to 45 Cetane
Japanese is Low aromatic IE 50 to 55 Cetain
Going to try to increase my Cetane #s and see what happens.
/ 2610D Injector pump timing #12
For what it's worth re. the diesel issue. I know that German car makers (especially VW) have been lobbying for significantly better quality diesel in the US for years. In light of that, that part of the comment by your mechanic makes sense.
/ 2610D Injector pump timing #13
Compression ratio of a diesel depends a lot on combustion chanber design. There are 5 and maybe more with recent designs, and each offer its own starting and operating characteristics. The Perkins I had in my MF 165 had a compression ratio of 15:1 and no glowplugs. Started easily in our winter time temps about mid-30's. Don't know what combustion chamber design Yanmar uses.
/ 2610D Injector pump timing #14
Hey Rock,
This is probably just too simple but I thought I'd mention it anyway...
Have you removed the intake tube (from the air cleaner) and tried starting your tractor since the new improvements? Was just thinking that the slightest restriction of air could be adding to cold start issues.
Also, I don't recall if you use your thermostart for prestarting the engine? As the design is specifically for pre-heating the enclosed atmosphere contained in the intake...I would think this would help significantly...NO?
Yes, I did try removing the intake air hose, it did not help. But now I have a turbo on it and am anxious to see if the turbine (exhaust) side of the turbo will help keep some heat in cylinders.
Yes, I do use a new thermostart. I do not however use the decompression anymore because I get a better start if I crank the engine with the fuel OFF. I believe the COLD fuel may hinder starting and so I crank with no fuel for about 10 to 15 seconds and then pull throttle lever.
I am going to wire the thermostart to a toggle switch so I can keep it on while cranking. My owner's manual reads that I should engage the thermostart system for a while AFTER engine has fired to help with cold weather starting. I figure if it is ok after engine is started it should not hurt while cranking???
If all this fails I am going to double check the valves and test actual compression.
I ordered a service manual for a 2610D and recieved a service manual for a 336D could someone tell me if the compression should be the same for a US model 336D and a Jap model 2610D Engine 3T80D?? If not can anyone tell me what the factory compression should be? I can correct for elevation after I have correct numbers.
Just a side note here but last March when it was below 30 deg F. I took my wifes hair drier out to a cold tractor and pushed the Hair Drier outlet into the intake side of the air filter and turned it on. Let it run for about 30 seconds and cranked tractor without thermostart or decompression lever and it started immediately!!! I mean maybe only 1 rev of the motor a POW it was started:)
/ 2610D Injector pump timing #16
Rock I am really interested in your turbo addition. When you get a chance some more comment and a pic or two would be nice. In the future maybe some other info like response and power comments. Especially when you get the size that you need. I understand that currently the turbo is too large and spends alot of time in surge, right?
About the hair dryer -- I had an old Ford transit van that had a 2.5 liter normally aspirated diesel. When it got very cold (below 0 F to -30 F) I had to regularly use the hair dryer or heat gun to give the thing a breath of warm air and it rarely did not do the trick in starting. Anything that will warm the intake air will help.
Mike
/ 2610D Injector pump timing #17
I had a Yanmar 1610D that I posted about here. It had low compression and wouldn't start w/o the Thermastart or cranking for 20+ seconds. I have bought a new JD 790 which also has a Yanmar engine and it has to crank for 10+ seconds to start at temperatures below about 80 degrees. I live at 8600ft. It starts instantly if the engine has been run (even a few seconds), if I use the intake heat (no thermastart, only intake heat on this tractor), or if I have the block heater plugged in. Throttle position or a diesel additive have not made a difference. At this point I just use the intake heat if it is below 80, which except for some afternoons in June, July and August it always is.
Thanks, Mech! I read your post but I could not tell if you were ever SURE that the tractor actually had compression problems or if it was the altitude.
I have used a hair drier to warm intake air and help pressurize the intake and tractor fired immediately.
Compression testing is a waste of time and $$$ unless I can determine what my compressions is supposed to be.
You like most everyone I have spoken with have issues at the elevations we are talking about.
I hate to type this but there is a product on ebay that may help us out. Its a gimmik for 99% of the population but for us it might be the ticket.
Its a high rpm motor hooked to a small fan that is electric (14 VDC). It plumbs into the intake line and pressurizes the intake manifold to about 3 psi. A switch turns it on and off. When off it just has minimal resistance and with my turbo will not be noticed. I am thinking of wasting $50 to see if it will work.
MJPetersen, sorry I could not post photos of turbo earlier but I took a hyd. cylinder off of loader to have a seal kit put in it and was told shaft needed replaced. It will take a week to get new shaft. I cannot open my hood to take photos of turbo until I get the new shaft and seal kit in. IE with loader down hood will not open. I will post photos and more details on turbo once I can open hood. SORRY!
/ 2610D Injector pump timing #19
Rock there is NO hurry I am just collecting info and am curious. Nothing will happen until winter at the earliest. I have lots to do otherwise before then.
Thanks.
Mike
/ 2610D Injector pump timing #20
The 1610D did really have low compression, from 300 to 340 psi across the 3 cylinders. The 1610 was supposed to have 23 to 1 compression which at 1000ft equaled 568 to 639 psi. At 8500ft it should have been 431 to 485 psi for a perfect engine. My book saids anything below 400 psi will be hard to start. So you see even a perfect engine is marginal at 8600ft. My 790 only has 18.5 to 1 compression but a different chamber design with top injection. My book says 355 to 440 psi is the specification and doesn't give any altitude correct. I haven't been able to get my dealer to respond to my altitude questions except just to say, "use the cold start aid then, it doesn't hurt anything". I guess it really doesn't hurt anything except these heating coils have, I suspect much shorter life than a diesel engine.
2015 Ford F-550 4x4 Mason Dump Truck (A66736)
2015 Ford F-550...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
