2610 HST & hydraulic filters.
   / 2610 HST & hydraulic filters. #1
Lee Robinson
Brandon, MS
Kioti CK2610 HST
I don't want to post the same topic twice, but thought some Kioti tech may be observing this section of TBN but not the hydraulic forum section...so here is a link to the original post.
   / 2610 HST & hydraulic filters. #2
Comes from the same tank, using the same oil but 2 different systems. I often thought the same, but the only reason I could think of was that the HST oil has to be as free of debris as it can be while going into the transmission.
   / 2610 HST & hydraulic filters. #4
Typically Even larger hydrostatic drives have a dedicated charge pump
Filter as well as other filters on the system. Filter element $30 new hydrostatic $3000 so filter is very inexpensive insurance
   / 2610 HST & hydraulic filters. #6
I have the same Tractor. Seems the manual is a bit unsure of service intervals for hydro filters and fluid after 400 hours? I did hydro filters and fluid at 50 hours and again at just shy of 300 hours. In the future I would like to do fluid and filters at the same time? What would you guys' recommend hour wise?
Thanks for the info guys. I am very pleased with the capabilities of the CK2610 HST.
   / 2610 HST & hydraulic filters. #8
While the tractor only has "one hydraulic fluid reservoir", it has a "2 step filtration" if you will. The HST filter is of a finer micron and rated for higher pressure and therefore more expensive than the regular hydraulic filter. Because of the nature of the tight tolerances on the HST transmissions, etc it is very important to use the correct filters and if you consider using anything other than OEM, make sure you do very good research and make sure you're using filters that are rated correctly for your tractor, or you could see expensive HST repairs.
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A56129)
2015 FREIGHTLINER...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
2018 Kia Optima (A55973)
2018 Kia Optima...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
