3-Point Hitch 2605H
   / 2605H #1
jd2030
John Deere 2030
3 point will not lift shredder
Fluid is full
Can move the lever up and down but it will not stay in position and wants to return to center nothing happens at the hitch
An suggestions?
   / 2605H #2
Does the three point lift if no load is on it? The tractor is fifty years old, There may be internal seals failing on the three point.
(1) HD 25ft x 24ft Metal Building Frame (A57453)
(1) HD 25ft x 24ft...
(4) Aluminum 6 Lug Toyota Rims (A57454)
(4) Aluminum 6 Lug...
Towable Sprayer (A59228)
Towable Sprayer...
Simpson 3400 PSI Pressure Washer (A57453)
Simpson 3400 PSI...
Margaritaville Metal Truck (A57454)
Margaritaville...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
