2555 Question
   / 2555 Question #11
I believe the fuse you are looking for is located in the RH post of the cab.
   / 2555 Question
Thanks. I plan in checking the center of the plug with a lighted tester for power and then check for continuity on the ground.
   / 2555 Question
***UPDATE***
The 2 issues are related. There is no fuse behind the lighter in the B post. The fuse for the lighter is in the panel under the steering wheel. It is labeled coupler. Don't know why?? After I replaced that fuse, The 4 way flasher started to work. Not being able to believe it, I pulled the the fuse I just replaced and the 4 way flasher did not work.
Hope this helps someone else.
   / 2555 Question #14
***UPDATE***
THANKS! .. This did help .. I have the same tractor you have and was going to hookup my electric sprayer and noticed my power outlet was not working ..
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
