2555 Mahindra overheating and leaks
   / 2555 Mahindra overheating and leaks
Thanks for the reply DirtHauler. They just replace the axle seals and the pto seal for the second time. Also they replaced the a/c compressor and now it sounds like it's coming apart after an hour of running it. This is definitely what I worry about when the "bumper to bumper" warranty is over after 2 years.
Welcome to 2555 problem club! Have that "service manager" get a hold of me and I'll give him an ear full! The hydraulic oil in these runs excessively hot no matter what. As an example, one day, after doing some mowing, I ran thru a puddle. The water splashed on the tranny case & immediately started sizzling and turned to steam! When I got home after trailering it for half an hour, I got my laser thermal gun and the case was at 232 degrees! So with that being said, this is what you have to look forward to; ALL seals and "O" rings below oil level line will "cook" and harden then leak; hydraulic hoses will start leaking at the crimped area of the connections. Other hose leaks will develop in areas under the floor pan due to the way they are routed over sharp edges etc. Your fuel supply line may start to leak 'cause the left brake rod rubs against it.
So this is what I've had to do to mine so far;
Replaced the HSU (hydraulic steering unit) due to it "pissing" oil twice, one under warranty, the second one out of pocket...... KAAACHING!
Replaced the PTO output shaft seal 5 times. (now keep at least 4 on hand) Don't buy the Mahindra/TYM brand, get them at a bearing/seal store, they're cheaper and a little better quality.
Had to have both rear axle seals replaced along with the expensive proprietary axle retainer nuts. I also had them install new axle bearings since they had it torn apart.
Replaced the seal on the tranny output shaft for the front axle drive shaft.
Had to replace the boot on the sub shifter due hardening and splitting.
Just replaced the "O" rings on suction line at filter adapter due to leakage and allowing air to be drawn into system along with the two short pieces of hose.
Have replaced 5 hoses, one of which was the pressure hose to the HSU...............royal PITA! NOTE: If you have to replace a hose, don't replace it with the same junk, have it made at a hydraulic shop..........better quality and they won't leak, just tell them that the fittings are "British Standard".
And every time you have to replace a seal/"O" ring, it requires you to drain almost 10 gals. of hydraulic because they're below the "water line". Dealers love this 'cause they drain it and sell you new!
Now I just noticed another drip, upon inspection, I discovered hydraulic leaking, of all places, where the clutch housing mates to the engine..........you know what that means!
P.S. If TYM (which I know) builds the tractor and Mahindra makes the engine, then why is the engine block stamped TYM ??
Hey can I get the serial # of your tractor so I can prove to mahindra that I'm not the only one with issue? Thanks
Update. After months of it being in the shop and countless reoccurring oil leaks I decided to trade in the 2555 for a new John Deere. 20180728_094059.jpg20180728_094059.jpg
   / 2555 Mahindra overheating and leaks #14
Nice machine. You will get good service out of that unit. More pictures please.
   / 2555 Mahindra overheating and leaks #15
You did the right thing. New machine looks very nice. Enjoy.
   / 2555 Mahindra overheating and leaks #18
I have a 2555 and I received a safety letter last year about a fire hazard if you get the electrical plugs wet on the fire wall. Well my tractor did catch fire this year and burnt the harness pretty good. I repaired the harness until the season is over, I do have issues now and and again. My question did anyone else receive a letter I have one about it moving when wet, I remember getting a letter about the fire hazaed. However, I can not find the letter.
   / 2555 Mahindra overheating and leaks #19
Checked the Mahindra campaigns for the 2500 series. Nothing about fire. There is a campaign for the water issue for the HST plugs. Its a seal kit for the plugs. Your dealer should be contacting you to do the work ! Its a mandatory repair. Costs you nothing.:thumbsup:
   / 2555 Mahindra overheating and leaks #20
Ok, thank you for the reply and the information.
Bear Compound Bow (A57453)
Bear Compound Bow...
John Deere 3025E (A53317)
John Deere 3025E...
Wright Sentar Stand on Mower (A57149)
Wright Sentar...
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
2016 FORD TRANSIT 350 HIGH ROOF VAN (A59575)
2016 FORD TRANSIT...
3 Point Hitch Single Bottom Plate (A57454)
3 Point Hitch...
