2555 blowing engine stop fuse
/ 2555 blowing engine stop fuse #1
baxley804
ga
none
I have a 2015 2555 with 62 hours that keeps blowing the 10 amp engine stop fuse. It will blow it when you turn the key to activate the glow plugs and when you turn the key to engage the starter. Any ideas of whats going on?
/ 2555 blowing engine stop fuse #2
Short in the GP circuit.Disconnect GP strip or heat coil and try it.:thumbsup:
/ 2555 blowing engine stop fuse #3
Check your wires to the plug and be sure a mouse hasn't made a home recently.
Yes, I had a bare wire on the wiring harness under the hood.
/ 2555 blowing engine stop fuse #6
Do you know the general location? Any other information would be MUCH appreciated and hopefully save me trip to dealer.
/ 2555 blowing engine stop fuse #7
The most common place is behind the dash were the harness has to make a hard bend and rubs against a length of metal
That's where mine was worn.
/ 2555 blowing engine stop fuse #9
Blown fuses is almost always the result of a frayed wire somewhere. That's why they put the fuses there in the first place. Wires are sized to the load and while fuses are sized to the wire. The real purpose of a fuse is to keep what ever it's protecting from catching fire. Whether it's your tractor, car, home, airplane or whatever a fuse does the same job.
/ 2555 blowing engine stop fuse #10
Finally found my problem. Insulation rubbed off wire closer down behind fuel pump against black painted hard fuel line right at gray plugjack. I have pictures but can't figure out how to post here.
/ 2555 blowing engine stop fuse #11
This is such a great site and with a great bunch of helpful contributors. I am going to find these two locations on my 2555 this weekend and wrap some old inner tube or something else around it as preventative. Thanks a bunch for sharing.
/ 2555 blowing engine stop fuse #12
i took a look and couldn't find where they are rubbing. could you provide a pic or two?
/ 2555 blowing engine stop fuse #13
Don't you just love the way Mahindra runs wires and hoses! I had a situation a couple years ago that drove me nuts! I'd open the hood to clean radiator screen and when I'd close it, a large blue spark would jump from the hood to the side cover! To make a very long story short, after striping the wire harness starting at the front, I found inside the plastic wire loom a red wire that had a spot with no insulation on it from the factory and was leaking voltage to the metal support thru the loom.
/ 2555 blowing engine stop fuse #14
Everyone is simply pointing out Mahindra's lack of attention to detail. I think the basic tractors is good but all that other garbage they hung on it has a problem.
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
80003CFL (A61568)
80003CFL (A61568)
