2545 foaming behind engine
/ 2545 foaming behind engine #1
pripyat
Sandhills, SC
Mahindra 2545
Haven't run the tractor in a couple months, started it up and I've got fluid everywhere. What is this overflow/blowoff hose behind the engine?
/ 2545 foaming behind engine #2
I can’t tell for sure but I’d check your oil, I’m guessing that’s coming from the pcv and you have water in the oil.
/ 2545 foaming behind engine #3
Looked like fuel to me. There is a fitting up by the firewall on the back of the engine. Very hard to get to. I had a friend with smaller hands than I have reach in and tighten a clamp.
Might be the same issue.
Oil looking good. Also drained the fuel filters. Lower one had sla bit of algae in it, the upper just had a little trash.
I'm having trouble IDing the fluid.. it's really oily but smells like old diesel.
The culprit is this 90 degree elbow that sits between the engine and the firewall, it slips onto a nipple on the top of the transmission. I was tugging at it with some long needle nose pliers (trying to trace it) and accidentally pulled it off, I have no idea how I'm going to get it back on there. :| I guess the fluid is hydraulic fluid and it's from a vent.
