254 Parts
/ 254 Parts #1
Wayne_Freeman
Beaufort, SC
Kubota L3400
If any 254 owners are near the lowcountry of south carolina I have a stash of Jinma 254 parts to give away. Pick up only!
/ 254 Parts #2
Wayne:
wish I was down that way.
I could use some :)
my 284/254 stash has been disappointing I think the parts that arrived that I bought are for a DF not JM. :(
Mark
/ 254 Parts #3
Hi Wayne_Freeman. I live in the Tennessee mountains. May be close to you. Have a 254 that has been parked for years. Just got it going again, ready to work and something blocked the fuel flow inside the fuel pump. Took the cap off and everything looked fine. Concerned about opening up the guts of the pump - lots of parts! Any ideas or do you have a working pump? Received this tractor in Raleigh NC on 5-20-97. Purchased it from Hardy Deisel I think. George Rowe at cabinnnn@bellsouth.net or reply here. I am a new member. Thank you.
/ 254 Parts #4
The first two posts are from over five years ago so you probably won't get a response...
I would look at the fuel hoses first, the rubber tends to swell with time and can block the flow. If your tractor is 17 years old they're due. Also the fuel filter.
If the fuel pump has been run dry it needs to be primed, there should be a hand pump on the side for priming.
Diesel fuel can get infected by bacteria, I know some posters have reported it but I don't recall the solution.
