2538 engine leaking air around injector ?
   / 2538 engine leaking air around injector ? #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
I have a 2538 with 160hrs, i was using it the other day in low range backing up a hill to rake down it when I hear air an puffing sound, i popped hood and i see air/hear "puffing" from what i believe is where fuel injector goes into top if cylinder and i think its the glow plug there also, i took to the dealership and dropped it off but havent heard anything yet, any ideas, sorry for the bad picture but there was also a alittle bit of oil around it 20180718_181253.jpeg
   / 2538 engine leaking air around injector ? #2
It doesn't use regular glow plugs. It has a heater grid (if thats what its called). The system runs sky high fuel pressure like 20,000+ psi. I would think that sound is a tiny amount of fuel escaping from a loose connection. Please update when its fixed.
   / 2538 engine leaking air around injector ? #3
That's a shame.. its about a 10.00 fix but your gonna get charge over a grand from the dealer..
It seals w/ a copper gasket & some orings for dust seals.. they're gonna tell you, you needed a NEW injector & they're gonna hit you w/ 4-5 hrs of labor..
You can PLAINLY SEE it has 1 fuel line, an electrical clip & is held down w/ an Allen screw.. 30 minutes tops..
You'll be VERY LUCKY if they don't tell you, you need a NEW cylinder head..
OR they might cover the whole thing under warranty..Lol
It would be nice if warranty covers it, thats why i bought a used but newer tractor to have some while still having 2 yr warranty, but i'd probably be happy if it still cost me only $1000, i bought this tractor used and cant afford any super expensive repairs, would this copper seal just be defective or worn out that may of caused it to fail or could there be a bigger issue
   / 2538 engine leaking air around injector ? #5
The thought crossed my mind of a leak coming from around the injector gasket but I didn't think quality control could be that sloppy.
   / 2538 engine leaking air around injector ? #6
Another TYM with an issue. Mahindra really needs to rethink the partners they're using for re-badging units.
   / 2538 engine leaking air around injector ? #7
The engine is made by Mahindra.
   / 2538 engine leaking air around injector ? #9
And the fuel system and electricals are all Bosch. So that’s a pretty good partnership. Wondering if the OP got his problem resolved?
I'm original poster not yet still haven't heard from the dealership kind of afraid to call them, lol
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
CFG Industrial MX12RX (A50121)
CFG Industrial...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
