Oil & Fuel 2523 fuel usage
/ 2523 fuel usage #1
cmkh3
Kitsap County, Washington
John Deere 322
Trying to figure out if the 2.25 gallon fuel tank the tractor comes with is big enough for a days work or how many times do you refil for mowing and tilling and general work in one day on 1 acre?
Thanks,
/ 2523 fuel usage #2
The 2500 series are good machines but thats a small tank....
You probably will have enough to mow a full acre...
The tanks visable guage is the only way to tell how well you are doing..
Ducati
/ 2523 fuel usage #3
I mow aprox. 2-1/2+acres and use a 2/3 of a tank with my 2523.
/ 2523 fuel usage #4
</font><font color="blue" class="small">( I mow aprox. 2-1/2+acres and use a 2/3 of a tank with my 2523. )</font>
Based on that i think I get worse /forums/images/graemlins/crazy.gif mpg (mow's per gallon )
I have a 3204 (4.5 gal) with the same acreage. I'm at half or a little under. The weight and shaft attachment makes a difference I'm sure. The motor being the same (Kohler)
Ducati
/ 2523 fuel usage #5
I have a 3235 with the 4.5 gallon tank and 25hp Kohler engine. I mow 1 acre and can mow it twice without running out of gas.
Bob B.
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
John Deere 1790 Planter (A66285)
John Deere 1790...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
2 Rolls of Screen (A62613)
2 Rolls of Screen...
