Oil & Fuel 2523 fuel usage
   / 2523 fuel usage #1
cmkh3
Kitsap County, Washington
John Deere 322
Trying to figure out if the 2.25 gallon fuel tank the tractor comes with is big enough for a days work or how many times do you refil for mowing and tilling and general work in one day on 1 acre?
Thanks,
   / 2523 fuel usage #2
The 2500 series are good machines but thats a small tank....
You probably will have enough to mow a full acre...
The tanks visable guage is the only way to tell how well you are doing..
Ducati
   / 2523 fuel usage #3
I mow aprox. 2-1/2+acres and use a 2/3 of a tank with my 2523.
   / 2523 fuel usage #4
</font><font color="blue" class="small">( I mow aprox. 2-1/2+acres and use a 2/3 of a tank with my 2523. )</font>
Based on that i think I get worse /forums/images/graemlins/crazy.gif mpg (mow's per gallon )
I have a 3204 (4.5 gal) with the same acreage. I'm at half or a little under. The weight and shaft attachment makes a difference I'm sure. The motor being the same (Kohler)
Ducati
   / 2523 fuel usage #5
I have a 3235 with the 4.5 gallon tank and 25hp Kohler engine. I mow 1 acre and can mow it twice without running out of gas.
Bob B.
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
