2520..So I installed a Temp Gauge
   / 2520..So I installed a Temp Gauge #1
PCABE5
Platinum Member
Wisconsin
John Deere 4066R Cab and loader
I was looking for something to do this weekend so I installed a temp gauge. Everything was really easy to hook up. My only mistake was I scratched the black plastic right below the gauge but I am sure the tractor will survive. Easier to read then the light and easier to tell when the front grille is getting clogged. The gauge reads 160 when it warms up which is when the T-stat opens.
   / 2520..So I installed a Temp Gauge #6
Nice!:thumbsup: I have been wandering about that and if they have an idiot light on them to let you know if it is getting hot.....
   / 2520..So I installed a Temp Gauge #7
There is a plug already there. Just remove it.
If you have a block heater (like me),that is already being used. Not sure,but I don't think there is anywhere else to put it.:(
Greg
   / 2520..So I installed a Temp Gauge #8
Greg
On my Kubota (B7100) I couldn't find a tapped hole for a temperature sensor, so I used some copper pipe fittings to make a short insert into the top radiator hose. I soldered a brass fitting into that copper section for the sensor.
Works great.
   / 2520..So I installed a Temp Gauge #9
Greg
block heater should be in the block on a 2520, not the thermostat housing...
look again...
   / 2520..So I installed a Temp Gauge #10
Greg
The block heater on my 2520 is installed in the side of the block. The fore mentioned plug is still there and is not big enough for a block heater.
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
MONOSEM NG-3 LOT NUMBER 267 (A53084)
MONOSEM NG-3 LOT...
