2520 - Rear Remotes Added
/ 2520 - Rear Remotes Added #22
Thanks Brad for the info. Seems either valve will work for the top and tilt... As long as I stay within the detent limit I would not use the regeneration function. Actually to keep it simple. It sounds like not having the regen function for top and tilt is a better idea..
Thanks again
Terry~!
I would agree - if you don't need the regen I would pass on it as well. Good luck let us know how you make out with the project
Brad
/ 2520 - Rear Remotes Added #24
I have not designed it yet. i will use the same valve kenny used.
it can not be mounted like kennys to work on a backhoe. it will haft to be
mounted low as possable and more foward. i got an idea in mind.
i will haft to build a bracket to show you. ;) I guess i need to get on the stick and do it. So i can make a bracket for everyone with a hoe.
that wants to add remotes....:D
Chris....:)
/ 2520 - Rear Remotes Added #25
I purchased a 2009 John Deere 4105. I need to install a hydraulic top link. There are no rear remotes on the back of the tractor and John Deere said it can not be done. I find that hard to believe. Could anyone suggest how I go about installing a rear remote on this tractor.
/ 2520 - Rear Remotes Added #26
The Power Beyond Kit for the 4105 is JD p/n LVB25505. You will probably need to talk to the sales person (not the parts counter) to get it.
Attached is JD's drawing of the PB kit for the 4105 from their parts website.
After that you add a valve as shown elsewhere.
/ 2520 - Rear Remotes Added #27
Hi Brad!
You dont have the partnumber for the valve you have used?(pic 4790 above) or proposed another valve which can be used for the job like you have done?
Regards Jarle
/ 2520 - Rear Remotes Added #28
Hi Brad!
Regards Jarle
Hi Jarle! This is an old thread and Brad have not post for a long time. You may want to give him a private message unless someone else can give you that info. Welcome to TBN and good luck. Henri :)
