2520 position control??
/ 2520 position control?? #1
chevyman1
Birmingham AL.
Can someone please explain to me what exactly what this feature is and what it is used for? I thought I knew but now that I have the tractor I dont really have a clue. any help will be appreciated.
/ 2520 position control?? #2
The way i understand it. you can control how far the rockshaft go's down .
like if you put the blade down to a certain point and grade and pull it up to make another pass , it gives you the ability to put it right back in the same position. at least that is my understanding. ....:)
you can inch it up or down a little at a time. you have more control. and a stop to set it where you want it to be.
Chris
/ 2520 position control?? #3
Well, I went from a 2305 (that didn't have) to a 2520 (that does). Before I upgraded to the 2520 I too was doing my homework and I thought the biggest feature was the ability to return it to a previous height setting, which comes especially useful when grading, snow blowing, etc. What I discovered was that this return-to-previous-setting feature was really nothing more than an adjusting bracket beside the 3ph lever beside the operator. If you want to adjust the return-to-previous setting, you loosened the wingnut, moved the bracket to where you want it and you re-tighten the bracket, and voila.. new height setting. This helps you do what Chris describes earlier, back and forth passes with a blade at the same height.
However once I started using the new 2520 with position control, I noticed one other huge difference (which I really really like, btw). The 3ph lever on the 2520 controls the EXACT position of the rear 3ph, meaning, you inch the lever forward on the slider by a little bit, it raises and little bit.. you inch the lever on the slider a lot more, it moves up a lot more. Meaning, the position of the 3ph height is relative to the lever position. This comes in especially handy when doing finishing grading, when you're trying to move dirt to strategic spots, raising/lowering particular areas with material, etc. etc.
On the 2305, the 3ph lever basically had three settings. Up, Middle and Down. When the lever was in the Up position, the 3ph is being raised.. when it's in the Down position.. it's being lowered. When the lever's in the Middle position, it's stationary. So getting the exact height you want is a matter of constant lever movement betweeen the three settings until you get it right.
I've done a lot of grading and material moving with the new 2520 and I can honestly say it's a very effective system for controling the height of your rear implement. If you plan to do a lot of work with your tractor, I think this position control feature allows you to handle the implement with a little more accuracy.
Hope this helps!
GordNovo
/ 2520 position control?? #4
Its awesome for using my flail mower. You just set the wingnut to where you want the cutting height, and then throw the lever forward till it stops and its set perfectely EVERY time. Then you can lift it a bit to do a turnaround, and throw it back forward and its all adjusted still!
Saves a ton of looking back and readjusting 10 times and scalping or not cutting short enough.
(2) HAY TEDDER WHEEL RAKES (A64280)
(2) HAY TEDDER...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2019 GREAT DANE CS1-1314-21053 53X102 DRY VAN TRAILER (A59912)
2019 GREAT DANE...
Sterling AT (A63689)
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
