Runner
Elite Member
- Joined
- May 12, 2007
- Messages
- 4,107
- Location
- Missouri
- Tractor
- 2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
Just a quick update on a 2520 performance issue I mentioned in my first impressions post on this unit. I had originally noted that the unit felt quite stable on the side hills I’m mowing with my 72 inch RFM, however, there was some sideways sliding and, due to the lightness in the rear of the tractor, I had to run in 4WD all the time for traction.
Last weekend I picked up a set of 4, 60lb JD wheel weights and have since installed and test driven them with both the 72 inch RFM and my 60 inch rotary cutter. I am pleased to say that the extra 240lbs on the rear wheels has solved the traction issue, and I now only really need 4WD for improved traction/braking performance on the very worst hills that have to be taken vertically.
While I’m not especially crazy about how they look, they do get the job done and will also be helpful in loader/pallet fork operations. The other neat thing about these is that the second (and third, if you have one) weights are very easy to stack on the first one once you have it installed.
