2520 No Start
/ 2520 No Start #1
prosperity
Platinum Member
North Central Pennsylvania
JD 2520
2520 purchased new July 2007 - currently 108 hours
Went to go mowing this morning - tractor started just fine and loaded on the trailer.
Get to first job - started right up - finished job and loaded on the trailer.
Get to second job - turn the key - dead. Get a faint clicking of the fuel pump with the key on - check headlights - very dim.
Bring it home for some diagnosis. Battery showing 12.7V. Checked the cells with a hydrometer - all showing great at the top of the scale. Checked all main cables between the battery/frame/starter - all perfect condition and connections good.
Hmmm....I remember reading here on the forum where these batteries will die just like that without notice. Did a forum search, and found a couple folks who had the same symptoms where the battery checked out good, but in the end a new battery solved the issue.
I've been through all the diagnostics/testing that I know - just isn't making sense. Even with a jump from my running pickup I get the engine to turn over once slowly and that it is.
So, I am now going to go with the consensus that I have read here and get a new battery. I just hate buying a new battery being this one tests good, but as I have read here, others had the same scenario where a new battery was the ticket.
/ 2520 No Start
Something so simple....
2 Deere dealers (1 - 50 miles away, another 75 miles away) none in stock.
Auto Zone - nothing
NAPA - none in stock - getting one brought in for Sunday from the warehouse.
After all this I sure hope it really is the battery!
/ 2520 No Start #3
Your right you would think that batteries would be in stock!
/ 2520 No Start #4
... Even with a jump from my running pickup I get the engine to turn over once slowly and that it is...
I had this problem, the only difference was that my tractor started immediately with a jump. If your tractor only turns slowly with a jump, check the starter.
I also read where your lights were dim, that is a sign of a bad battery.
Good luck troubleshooting
/ 2520 No Start #5
:thumbsup:I have had a low battery that a good battery could not jump. The good battery was draining into the bad and not enough current flow to start. With the old battery pulled and a jumper stuck in the tractor started.
I do not believe I need a special battery for my tractors. I only go with size and cranking amps. I put a car battery clamp in the front of my JD4410 and can use 90% of anything at Walmart with old style top posts. Many have top and side. I look at price, quality, size, crankamp.
/ 2520 No Start #6
You can take the battery to a parts store and they'll load test it. It will most likely fail. If you have a voltmeter hook to the battery and watch the voltage as you try to crank the engine, if the voltage drops off below 7 or 6 volts it's likely junk.
/ 2520 No Start #7
Hiya,
Dim lights, slow or no crank? I would look to the ground circuit. Make sure the ground cable connection from the Neg terminal to the chassis is nice and clean and making good contact. Check to make sure if the cable has a lug on the end that the cable is in good condition where it joins to the lug. Check the Pos cable as well. I have seen cables that look perfectly fine on the outside and have 1 strand connected.
Tom
/ 2520 No Start #8
Had this just happen to me on my JD 455 started fine used it then shut it off for a few min to do something when I went to start it was dead nothing. I was ready to buy a new battery but decide to remove the cables and clean both pos and neg also the battery posts with wire brush once shine was achieved reconnected and tighten. problem solved has been fine ever since so give it a try nothing to lose. Good Luck
/ 2520 No Start
Thanks for all the help and ideas.
I checked and double checked all the cables and connections - all good, no corrosion anywhere - all connections good and tight, etc. Also cleaned the battery terminals and cable ends.
Picking up the new battery tomorrow - will update tomorrow evening with hopefully good news.
Edit to add: Thanks for the tip Greenblood2011 - I am going out to the barn right now to check the voltage on the battery while trying to crank.
/ 2520 No Start
OK - battery measures 12.67 volts.
I had my wife turn the key while I had the volt meter hooked up - when the key is on "start" voltage reads 2.87 volts.
Now I feel better about buying a $100 battery!
And my wife is so proud of me dragging her out to the barn in the dark.......
/ 2520 No Start #11
If you shop around you can find a battery cheaper I bet. You don't have to go the dealer. Take a picture of the top of the battery or if you can read the numbers on it still call around with that part number. Most battery stores can look it up by application too.
/ 2520 No Start #12
That is how the battery went in my 2007 2520....worked fine then suddenly didn't work at all. No signs whatsoever of it getting weak....not a bad way to go I guess?
/ 2520 No Start
Fire in the hole!
Installed the new battery and fired right up.
Thanks to all who've contributed. Between the help in my thread here and a good forum search, the problem is solved.
It is just so weird that these batteries die so differently than any car/truck battery.
On to bigger and better things - thanks all!
/ 2520 No Start #15
Vibration and bouncing around in a tractor knocks the cells loose which causes them to short out. It's common in industrial equipment for a battery to fail. Glad we could help you.
/ 2520 No Start #16
prosperity glad to read that your problem is solved!
Kudos for posting what the final solution was :thumbsup:
I hate to follow a thread and the OP stops posting and doesn't tell us the solution/fix.
/ 2520 No Start #17
One more thought to consider regarding batteries. I use a battery charger-maintainer on all my equipment and vehicle batteries. If you are not familiar with them you can pick one up at the JD dealership or most automotive stores. It is different than just a battery charger. You can leave them connected indefinitely. They will considerably extend the life of your batteries. My maintainer cost $25 from the dealer. Works like a champ. My battery is 5 years old and in perfect technical condition.
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
John Deere 5420 Tractor (A65579)
John Deere 5420...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
Landhonor Livestock Chute w/ Scale (A66408)
Landhonor...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
