2520 moving the trailer
/ 2520 moving the trailer #1
gunmaker
nw nj
jd 1025r / x750
When I got the 2520, one of my hopes was to be able to use it to jockey the ole airstream about. Today I finally got everything set up to give it a try. I hooked up a Northern Tool 2" receiver adapter to the I-match on the 2520 and went to work.
The 2520 handled the weight, both tongue and pulling, without difficulty. I was able to move the trailer about confidently, and did not feel any lightness in the front. I think long term that I will add a few pounds of ballast up front if moving over uneven terrain, but on the driveway it feels fine.
I was surprised when I set the parking brake and got off, parked on a slight slope, that the weight of the trailer was able to pull through the parking brake. It held fine when physically applying the brakes, but tended to creep when the parking brake was left to hold the load. I'll have to see if there is some adjustment to the parking brake possible.
For info, the trailer is 8000 lbs. and 31 ft. long.
I've seen a few others ask the same question...here's the answer.
/ 2520 moving the trailer #2
LOL ! now thats a rig - what do you use to tow it normally?
I would be the first to say, I would be nervous with an 8,000 lb 31ft monster behind my 2520. It can pull it and handle the tonque weight but my gosh if it ever got some momentum - :eek:
/ 2520 moving the trailer #3
Duc , dont be a Wimp......:D if you can hook it up then pull it..;)
That is awsome looking. it is amazing what it can do. ;)
Gunmaker there is and adjustments for the brake. look under at the brake peddles there is a rod on each side of the tractor going to the wheel hubs.
about hafe way up the rod there is and adjustment nut.
be sure to adjust both evenly....:)
Chris..:)
/ 2520 moving the trailer #4
Gunmaker, that's a pretty slick set up.
On a separate note, how well does your 72" front blade work? I'm thinking about upgrading my snow removal capabilities from the 200cx and would be interested in your experiences.
Mike- The 6 ft Meyers blade is awesome on the tractor. I've plowed paved road, gravel lane, and driveways of all description. It throws snow well in high range at full speed, or piles it high in low range. I feel that the 6 ft blade is the right size for the tractor, 6 1/2 ft would probably be fine also, it just seems to be the right balance in all circumstances. I'll never put the 54" blade on the tractor again.
I 'helped the neighbors' so much this past winter that I feel it equates to 6 or 7 years of plowing my place, and it convinced me that this set-up is a durable and reasonable match to the tractor and JD's hydraulics.
Just to recap the project, I used the JD factory hydraulics and mounts, a donated Meyers 6 ft blade, and fabricated a frame for the blade that allows it to mount to the JD quick-hitch system. It was an inexpensive weekend project.
Chris- thanks for the tech heads-up...Duc-a Dodge 2500 diesel does the trick!
/ 2520 moving the trailer #6
Looks good. The NT hitch fits the iMATCH?
/ 2520 moving the trailer #7
Gee, and i thought I was brave going almost vertical in a ditch to cut some grass. Towing that trailer around is a feat!:eek:
Yes, it just fit. I had to assemble the I-match top-link bushing, when the NT hitch was in place on the I-match. There is not enough room in the top of the NT adapter for the top hook of the I-match to be able to slide through when assembled.
/ 2520 moving the trailer #9
gunmaker said:
I think long term that I will add a few pounds of ballast up front if moving over uneven terrain, but on the driveway it feels fine.-------------------
Yes some weight in the bucket might be a good idea. Also, I can't tell from the photo if you have any provision to prevent the 3ph from lifting up when you are on that uneven terrain. A chain from the top of the receiver adapter or I-match down to the draw bar would prevent the trailer ending up on its tail.
/ 2520 moving the trailer #10
Gunmaker,
Great post. I was curious about towing ability also because I will be moving around a 24 foot cuddy cabin boat weighing around 5000 lbs when I get my 2520.
What is the tongue weight on the airstream?
Runner
/ 2520 moving the trailer #11
I had the same plan for moving my 25' trailer with my 2305. The tractor handled it just fine, but I didn't. My driveway has some slope and I was (as intended) trying to maneuver in some fairly tight quarters. What surprised me was how much the lack of visibility was unnerving. I'm pretty good at putting the trailer wherever I want it to go with the truck (forward and backwards). Apparently using the mirrors plays a big part in my confidence. Just pulling it forward out of the shed made me feel blind. I was surprised because I move my large flat bed trailer with the tractor all the time without hesitation. I ended up hitching up the truck to put the trailer away.
I suppose I could mount some huge mirrors on the front of the tractor and try it again. Glad you're having fun!
There's just over 800 lbs tongue weight on the trailer. To be honest, I couldn't ask the better half to snap the photo til after I knew it worked. I was afraid I might end up with the tongue on the dirt and the front wheels of the tractor pointed skyward. Another potential family memory for the album moment.
/ 2520 moving the trailer #13
FortClatsop,
I know the feeling about "driving blind" when maneuvering a trailer in tight quarters. In my previous home, I pulled an 18 foot ski boat in and out of my garage with my JD185 lawn tractor. The space was so tight, I couldn't do it with my truck.
I would actually put the hydro lever in reverse and let the trailer creep backwards, then, get off and walk to the back of the trailer to see exactly where it was going. It moved so slowly that I had time to walk back to the tractor and make steereing corrections to get it exactly where I wanted it.
Don't think I'll be trying that trick with the 2520....
Runner
/ 2520 moving the trailer #14
I had the opportunity to hook up my JD 3320 to my 30' Terry Travel Trailer with 12' tipout. Weights in around 9000lbs. Surprisingly it handled extremely well and pulled the trailer right up the slight grade in front of the house and backed it down the driveway. I have to admit I had a rope tied to the break-away brakes to pull if it got away from me.
RunsLikeADeere Photo Gallery - John Deere/John Deere 3320 pulling 30' Terry Travel Trailer Camper
Click on the pictures for full size.
/ 2520 moving the trailer #16
Do you press the brake pedal when you apply the emergency brake? I bet that will help.
D.
/ 2520 moving the trailer #17
My old 4100 has the same issue with parking brake. Its pretty much worthless except on flat ground where you don;t need it much anyway. So as an additional measure, I generally leave the hydro in gear when I park.
I much prefer to connect a trailer to the fixed drawbar than the 3-point arms. That way it cant bounce up on you and the leverage is less for tipping the tractor backwards.
Also, be sure and connect the safety chais to something. I had the coupler on my boatr trailer come loose on me backing it down the driveway and had happened to hook the safety chains on the 3-point arm just to keep them from dragging on the ground. I was really happy I did!
Finally, remember that if your tractor weighs 2000 lbs and the trailer weighs 9000 lbs, on any kind of a slope with less than perfect traction (like wet grass or loose dirt) , the trailer is going to overhwelm the traction of the tractor and you are going to get pushed down the hill brakes or no brakes. I would stick to very level areas and stay well away from any ditches or hills.
- Rick
Common sense helps improve safety!
/ 2520 moving the trailer #19
Gunmaker, I see from some of your posted pictures that you have turf tires on your 2520.
I have also have 2520. I want to change the wheels and tires to the turfs. Would you be willing to look at your wheels and find the part numbers stamped into them and post your findings here or email me at markaspinwall@yahoo.com?
Thanks,
Mark
/ 2520 moving the trailer #20
Thanks,
Mark
Mark, those are R4 tires on GM's 2520.
2016 FREIGHTLINER CASCADIA (A67714)
2016 FREIGHTLINER...
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2007 JLG 660SJ SKYPOWER TELESCOPIC BOOM LIFT (A65056)
2007 JLG 660SJ...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2014 PETERBILT 389 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A68363)
2014 PETERBILT 389...
