2520 Just keeps getting longer
   / 2520 Just keeps getting longer
Everything is asphalt. I set it up at first with the shoes up so the shoes & blade both contacted the ground. I thought it was a bit rough on the drive so last week I lowered the shoes to give 1/8" clearance at the blade.
The storms of the past several days started as freezing rain, then sleet, ending in snow. It has been real cold so there was a good base of ice in place. Bottom line is that I don't know if raising the blade made any difference. I use melter only on the hill - from the house to the road. The combination of the melter and the sun on the southwest facing drive keep that part mostly clear.
Keep in mind that the blade is double sided. If you start to get too much wear, you can flip it and lower the shoes.
   / 2520 Just keeps getting longer #22
You probably have more in your JD then I do in my Ford 7710 AND JD2555! (Both were purchased used).
David from jax
I probably will agee with leaving NJ behind, but right now the trip is rough!
2015 Nissan Sentra Sedan (A55758)
2015 Nissan Sentra...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54756)
PREDATOR TRI-FUEL...
2006 Nissan Titan Crew Cab Pickup Truck (A55788)
2006 Nissan Titan...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A54865)
2004 Ranger 195 VX...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
