Tires 2520 Front Tires Rubbing
   / 2520 Front Tires Rubbing #1
AKKubota
Alaska
JD 2520
I purchased the JD front wheel spacers anticipating the need for the room to fit front chains on this winter. Now, when I turn my wheel the tires rub on the FEL mount.
Dealer says to remove the spacers and don't run chains on the front. I need 4x4 chains.
Will the JD factory chains work W/O the spacer? Or does someone else have a recommendation?
thx
   / 2520 Front Tires Rubbing #2
Hiya,
What type tires? R4's or turfs?
Tom
   / 2520 Front Tires Rubbing #3
As close as the tires get without chains, like 3/4 inch or less, I'd be surprised if they would clear with chains, even without the spacers.
   / 2520 Front Tires Rubbing #4
Hmm... I've got a couple of friends with 2520's. The ER doc doesn't use chains on his and the other fellow - not sure.
I'm guessing that you have the wheels turned out to the wide setting, yes? To my knowledge, the R1's, R4's and turf (R3's) wheels can all be turned in or out.
As well, the local JD dealer here (they're all Craig Taylor - statewide) obtains chains from Anchorage. I can get the distributer for you - send me a PM.
As a last resort; you might consider cable chains. They'll help maintain steering and will improve traction (although not as much as chains..). Or auto chains. They're lighter and have smaller links (1/4") than equipment chains.
AKfish
   / 2520 Front Tires Rubbing #5
Another thought... (my 2nd one this week)! Have you tried mounting the rims on the narrower setting WITH the spacers; most likely - had to ask?! And the tires still rub the FEL?
AKfish
   / 2520 Front Tires Rubbing #6
I know on my 2520 with ind tires, it makes no difference on the front wheels if turned in or out - same overall width and clearance.
Ref. which tires: R-4's.
AK Fish: The tractors down at Craig Taylors right now getting a snow blower put on it. They recommended that I not run chains on the fronts.
I hadn't thought of the cable chains. I called the guys at tirechains.com and they said they could make me a set that didn't "drape" very much on the back and that might really help. I probably will just try rear chains to start and we'll see how that goes. I know from experience with trucks and my larger Kubota that the front chains make a huge difference on the ice or on compacted wet snow. I live on a steep hill and without front chains the unit will surely "pivot-slide."
   / 2520 Front Tires Rubbing #8
I couldn't/wouldn't want to use my tractor without chains on all 4 wheels!! With hard-packed snow or worse - ice - the front end would be wanderin' all over the place and it's really bad when I've got a load of snow in the front bucket.
I'd guess that with a front mounted snowblower you'll be crabbin' this way and that way quite a bit this winter!! (You'll get good experince using your rear brakes..)
Maybe those guys in the Anchorage dealership will put in writing that they'll be over to pull you out of the ditch when you get stuck??
R4's are the worst on snow and ice.... the tires are stiff and the rubber compound is hard and they're heavy ply to boot! Driving on them in the winter without chains is like a movin' duck across a frozen pond!
AKfish
I agree on the 4x4 chains.
   / 2520 Front Tires Rubbing #10
With these chains on just the rear, they stick like glue even on Ice. However, I learned that we don't get enough ice to justify dealing with the very heavy chains. So, I would let mine go for half price (original cost was $500) if one came to Montana to get them.
Mower King SSRC72 QA 72" Brush Cutter (A57149)
Mower King SSRC72...
Lot 14 Boxend wrenches and other wrenches (A59213)
Lot 14 Boxend...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
New/Unused Fuel Delivery Tank with Pump (A57453)
New/Unused Fuel...
John Deere 5055E (A53317)
John Deere 5055E...
JOHN DEERE 348 SQUARE BALER (A58216)
JOHN DEERE 348...
