Tires 2520 Front Tires Rubbing
   / 2520 Front Tires Rubbing
Those are tire chains look quite nice and appear to be the same type I had on my Kubota. I did buy chains yesterday - front and rear. The dealer removed the front wheel spacers and told me they won't work with my rim/tire size.
I bought some small 2 link garden tractor chains for the front that don't come down too far on the sidewall. They look like they'll be fine. I got some very robust chains for the rear.
Dealer also put the new lift arms on my 3-point with very little discussion.
   / 2520 Front Tires Rubbing #12
Good news.. glad to hear that you worked out a solution for the chain issue.
And really good news on the 3pt replacement -- Craig Taylor comes thru!!
AKfish
   / 2520 Front Tires Rubbing #13
I purchased the JD front wheel spacers anticipating the need for the room to fit front chains on this winter. Now, when I turn my wheel the tires rub on the FEL mount.
Dealer says to remove the spacers and don't run chains on the front. I need 4x4 chains.
Will the JD factory chains work W/O the spacer? Or does someone else have a recommendation?
thx
I've got the same issue and I'm keeping the spacers due to the incline in my yard. You can easily take your front tires to a local tire shop and have them siped. That's just cutting extra edges into the current treads. That helps a little. You can also screw these studs into your tires but that may exacerbate the rubbing problem. Maybe just do the rears and sipe the front. Better yet just get a set of turf tires for the front when you're on snow.
Tractor Tire Studs | Grip Studs® Screw-In Tire Studs | Traction in Ice, Snow and Dirt | Tractor Tire
2025 Chery 14ft Bi-Parting Gate Cow Motif Style (A56859)
2025 Chery 14ft...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
Xtreme Power MIG 195 (A57454)
Xtreme Power MIG...
1ft Bucket Smooth or Cutter Teeth (A57454)
1ft Bucket Smooth...
INOP/NON-RUNNING 1997 Land Rover Discovery Multipurpose Vehicle (MPV), VIN # SALJY124XVA557589 (A57453)
INOP/NON-RUNNING...
UNUSED FUTURE SGB20 20" HYD STUMP GRAB BUCKET (A58376)
UNUSED FUTURE...
