2520 Bucket Hook Project
   / 2520 Bucket Hook Project #1
Chris2520
Platinum Member
Marietta GA.
Thought i would share this weekends little project with you all.
Well i figured the new 2520 needed some bucket hooks. So i called AW-direct , and had them send me 2 grade 70 3/8 hooks. there rated at 6,600 pounds. no danger in me ever hurting them with a 200CX loader. or any loader for that matter. Well i new the loader bucket was not up to heavy tasks. so as you will see from the pictures. i put two 1/4 inch gussits under the full length from front to back under the loader cuff. as that where i figured the bucket was the strongest. so thats where i decided to put the hooks. I welded a 1/4 inch plate 4X6 on top of the bucket. then as you see i wraped another band over the lip of the bucket. so if your chains were pulling down you would not bend the lip. then i welded the hooks on. and of course repainted the bucket. inside the bucket i just grinded it smooth and painted. no need to spend a whole lot of time on it. as the first scoop of dirt and it wont matter much. The top side is a different story. i spent several hours blocking and sanding the top. it is slicker now than it was new. I know its going to get scratched sooner or later. but it being a new tractor. i could not do it hafe way. it had to look good. there is no danger in me ever bending the top edge of this bucket with a 200CX . I cant say enough about the factory JD paint. it is 9 dollars a can. but it is the finest spray paint i ever used . it go's on smooth and matches perfect.
Check out the pics and let me know what you think.;)
Chris....:)
   / 2520 Bucket Hook Project #2
Looks great! :)
   / 2520 Bucket Hook Project #3
Nice job!
   / 2520 Bucket Hook Project #8
Those came out great. I especially like the braces you welded underneath. You'll never bend the top edge with those.
   / 2520 Bucket Hook Project #9
Wow... that is beautiful! I don't know a welder from a hole in the ground, so I may have to hire this out. Really nice though- not just a great idea, but great craftsmanship! Thanks for sharing the pictures.
   / 2520 Bucket Hook Project #10
My bucket is on its way to you !
Nice Job- better than a pro's
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
