2520 50 hours service
/ 2520 50 hours service #1
Piedmont
NC, USA
JD 2520
Do most of you perform your own 50 hour service? My dealer made it sound that way. I wondered how many perform this service and if so at what point (hours) do you have the dealer take care of the service?
/ 2520 50 hours service #2
I would say most people do it themselves. You get to know the "in's" and "out's" of your tractor by doing it yourself. I do all my own maintenance and don't plan for the dealer to do any. If you can change the oil in a vehicle than you'll be fine.
/ 2520 50 hours service #3
Agree with above.
Its pretty straight forward for anyone with a little knowledge of vehicle maintenance. The manual does a decent job of explaining the procedure.
/ 2520 50 hours service #4
I did my own on a 2320.. It pretty much took most of a Saturday morning, but I was not in a rush and had some problems when refilling the transmission/hydraulics..
BTW IIRC- some manuals say to change the hydraulics at 50 and others say at 200.. I would change it at 50 just to get the metal shavings out of there..
I went back with Amsoil fluid for the refill, but I was told the JD low viscosity Hy-Guard is also synthetic. I have not been able to confirm it is synthetic though.
there is a current post on someone doing their 2520 50 hr service that has some advise in it - you may want to take a look there as well
Brian
Thanks for the input, I found the other post and it was very helpful,.
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
CHECO GREASE UNIT (A68842)
CHECO GREASE UNIT...
2008 Sterling L7500 Series T/A Vactor 2115-824 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
1994 MACK CH613 FUEL AND LUBE TRUCK (A67714)
1994 MACK CH613...
