2520 3pt Bleed down
/ 2520 3pt Bleed down #1
PCABE5
Platinum Member
Wisconsin
John Deere 4066R Cab and loader
I have a couple questions, First overnight the deck will lower the 3pt is that a normal function for the 2520? Seems if I open the rate of drop valve the faster it will bleed down when the tractor is off and if I slow the rate of drop the less it bleeds down.
Second question, is on the rate of drop valve, I only have to barly move the knob (16th of turn) to make a big difference, is that what others are seeing?
/ 2520 3pt Bleed down #2
I noticed the same thing on the rate of drop control. When I first got my 2520 (about two weeks ago), the first time I lowered the 3-pt (with rotary cutter attached) it slammed it to the ground. Seems like I had to turn the knob a ways before it stopped slamming it down but then it didn't take hardly any adjustment to make a big difference. In other words, the useful range of adjustment seems very small.
I would agree one useful range, if it were a clock I would say you have at most 5 minutes on a clock face from closed to slamming down.
If you are anywhere within that 5 minute range will yours bleed down if you left the mower on or some other 3pt attachment on and raised?
/ 2520 3pt Bleed down #4
This would depend on how much weight is on the 3PH. Mine will slam to the ground with the ballast box on but with it off I need to push the 3PH down with my foot.
/ 2520 3pt Bleed down #5
I have mine set so the 3PT will drop fairly slow,how slow,I don't know,but I don't have to help it down. Even with the BB on it won't drop completely, maybe halfway overnight. Same when I have the deck installed,maybe just halfway. I usually lower everything anyway,it's just when I forget is when I see how much it leaks down.
Even with the tractor not used for days,the mower won't leak all the way down.
Greg
/ 2520 3pt Bleed down #6
I know the FEL and Backhoe will leak down but I don't believe the 3pt should. At least my 3pt does not, even left up for weeks without moving the tractor, with a full ballast box. So what is the correct answer? Should it or shouldn't it?
/ 2520 3pt Bleed down #7
same here (2320) -- left the box blade or ballast box on for weeks and no leak down on the 3ph.
/ 2520 3pt Bleed down #8
I've never left mine with an attachment lifted so I can't comment on the bleed down. I always store it with the loader and box blade lowered to the ground. I'll try leaving the box blade raised a little bit some time and see what happens.
My old 2320 would not leak down either if I left something raised. The new 2520 I notice that the MMM will lower the 3pt some overnight and the amount that it lowers is dependent on the rate of drop valve position. If I have it set for faster MMM lowering the deck will lower more overnight. If I slow the drop rate of the deck then it will settle less overnight. I should say that the MMM I sometimes just leave up but attachement on the back or the loader I lower when I park it.
I am only asking because the 2320 did not leak down and I realize these are two different tractors but I was just wondering what it should do or is this a normal condition. So is this normal for the 2520?
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
