2520 / 200CX Specs?
/ 2520 / 200CX Specs? #1
Mike5252
Cleveland, Ohio
JD 2320
I recently picked up a 2520 with 200CX FEL. Where can I find information on the specifications for this loader? I've checked the JD web site and my 200CX manual - but couldnt' find anything.
What I'm looking for is information like, max lift capacity, max lift to 60", etc, etc.
Merry Christmas everyone
/ 2520 / 200CX Specs? #2
Check the loader manual close to the back of the book
minimax
/ 2520 / 200CX Specs? #3
/ 2520 / 200CX Specs? #5
MANUFACTURER
MODEL John Deere
200CX on 2520 Tractor
Loader Bucket used ---
Bucket weight, lb. (kg) 183 (83)
Lift capacity at full height, lb. (kg) ---
Measured at pivot (U) 902 (410)
Measured at 500 mm ahead of pivot (V) 629 (286)
Measured at 800 mm ahead of pivot (V) ---
Lift capacity at 59-in. (1.5 m), lb. (kg) ---
Measured at pivot (W) 1124 (511)
Measured at 500 mm ahead of pivot (X) 827 (376)
Measured at 800 mm ahead of pivot (X) ---
Boom Breakout Force, lb. (kg) ---
Measured at pivot (Y) 2239 (1016)
Measured at 500 mm ahead of pivot (Z) 1515 (687)
Measured at 800 mm ahead of pivot (Z) ---
Bucket Rollback Force capacity, lb. (kg) ---
At maximum height (VV) 1596 (724)
At 1.5 m (59-in.) lift height (XX) 1994 (904)
At ground level line (ZZ) 1702 (772)
Dimensions
Maximum lift height, in. (mm) (A) 78.5 (1993)
Clearance ---
At full height - bucket level, in. (mm) (B) 72.2 (1832)
At full height - bucket dumped, in. (mm) (C) 58.5 (1487)
Overall length (I+F), ft. (m) 9.616 (2.932)
Overall height in carry position (J), ft. (m) 3.858 (1.175)
Digging depth, in. (mm) (H) 3.9 (100)
Reach ---
At max. height, in. (mm) (D) 29.5 (750)
At ground level - bucket level, in. (mm) (F) 50.3 (1277)
Bucket Angle ---
Dump angle, degrees (E) 38
Rollback angle, degrees (G) 25
Dump angle, ground ---
Cycle times ---
Loader raise, seconds 3.19
Loader lower, seconds 1.95
Bucket dump, seconds 3.19
Bucket rollback, seconds 1.95
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
Kobalt Table Saw (A64119)
Kobalt Table Saw...
CRATE OF NEW PARTS (A64280)
CRATE OF NEW PARTS...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
