250 AS Belarus Hydralic Lift Quit
   / 250 AS Belarus Hydralic Lift Quit #1
kyguy
250AS
OK Laugh I am, $5,000 for 15 years of tractor use aint bad. Been maintaining the old thing pretty well. 3Point started sticking in whatever position it was in ocassionaly. Joggling the control would get it moving again. Now it has Quit working all together. Cleaned filters, opened the footbaall plate on the hydralic control valve to flush that point out. Normally you crank the engine over and it flushes obstructions out of control valve. Now there is no fluid coming out at all. Took test plug out of Hydralic Cylinder and no pressure at all. And old post on here says Dual Compensator Spool could be the problem. If it is clogged you get no fluid flow. Where is that located on the 250? Been over the pump and lines and dont find anything that looks like it. The problem appears to be plugged valve or bad pump. Dont want to order new hydralic pump wait a month for it and be back to square 1 when I install a new pump. I will appreciate any advice, even if you say Junk It.
   / 250 AS Belarus Hydralic Lift Quit #2
Try dedicated forum like MTZ Tractor Talk - Index
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
20800 (A56859)
20800 (A56859)
2019 CATERPILLAR 289D SKID STEER (A60429)
2019 CATERPILLAR...
2017 VOLVO SD45B PADFOOT ROLLER (A60429)
2017 VOLVO SD45B...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
