HammA5690
I have a 24x24 concrete pad that a house previously sat on before I purchased the property. I have not yet checked if it has a 3 ft footing around the outer edges but IF it does I was wondering 2 things.
In New York can you :
- build a garage over an existing pad without permits because there is part of an existing building already in place?
- would I be able to bolt a sill plate or 4x4 supports to the concrete pad and expect it to hold up the building?
I would much rather bolt a sill board down and stick build it or bolt the 4x4 to concrete metal adapters ad pole barn build it than set footings for the poles around the perimeter of the pad. Any help would be great, Ill most likely be asking the town code enforcer the same questions soon.
Thanks in advance!
Thanks in advance!
