2400h A1100N2 engine power increase
   / 2400h A1100N2 engine power increase #1
JeffinNB
2016 Branson 2400h with SL00 FEL
Does anyone know if the power from the A1100N2 in the 2400h can be turned up by adjusting the screw on the injection pump?
   / 2400h A1100N2 engine power increase #2
I imagine you could squeeze a couple more HP, not much, but with some smoke most likely.
They used to make a 2800 (28hp) model in the US and a 2900 (28hp) along with a 3100 (31hp) in Europe, using the same engine but with a Turbo.
   / 2400h A1100N2 engine power increase #3
Jeff if u want to send me a picture of the pump and point to where u think the fuel screw is, I’ll lead u down the right path and try to keep u out of trouble..
My screen name at aoldotcom
   / 2400h A1100N2 engine power increase #4
Any progress on this?
I don't know how your engine power is robbing you, and turning the IP up might work. What I suggest can help you/all of us get more use from our tractors in matching the load/work to its size and is also applicable to any size tractor.
1. Check the hydraulic pressure and bypass at the spool to ensure you have proper psi giving the correct lift capacity.
2. A tooth bar would aid in braking up hard soil and dig or fill your bucket easier.
3. Added weight would permit greater engagement with the earth and pulling power.
4. Ag tires for agricultural work, R4 for industrial use.
5. Working in lower/low range allowing full horsepower to be transmitted to tractor (Requires more time, easier on tractor).
6. Working in a higher range with lighter/looser materials to gain momentum/inertia with the weight of tractor to fill bucket or traverse terrain (Can damage tractor and property if you have miscalculated).
2016 Chevrolet Tahoe LS SUV (A48082)
2016 Chevrolet...
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
Deere 9965 Cotton Picker (A51039)
Deere 9965 Cotton...
Peterbilt Neon Sign (A48082)
Peterbilt Neon...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
