2386 Fuse box location
/ 2386 Fuse box location #1
bridge4
Platinum Member
Western,MA
Mahindra 2638, Bobcat MT 100
Hey Guys, My stereo is out, and I want to make sure its not a fuse before I waste too much time. I took the lower steering plastic off (and all 5-6 bolts!:mad:) and did not find a fuse box like I was led to believe. A quick engine look didn't have one jump at me either.
I cant imagine you need to take all those bolts off to check a fuse! Where is the box guys!! PLEASE and thank you!
/ 2386 Fuse box location #2
On my open cab is is right above the floor between your brake pedals and hydro pedals.
Is it covered by your steering panel? There is a small black plastic box with a single screw or something right below the grey plastic of the steering column. If thats it, it would make sense. I just need to be a risk taker and pull it I guess.
/ 2386 Fuse box location #4
That sounds about right, I don't think I had to remove anything other than the one screw on the fuse box cover.
Should have posted this thread first of all! Will check either this afternoon or tomorrow, thank you!
