2375 backhoe Leaky Control Valves
/ 2375 backhoe Leaky Control Valves #1
Duckdogs
Ohio
Kioti CK30
I've had a leak at the control valves for some time now but recently it has accelerated. I assume there are seals & maybe O rings that are replaceable. Is there a factory manual available? Does anybody have a copy? An exploded diagram would be helpful. Are there any special tools required? Does anybody know if the valves are a Kioti product? I didn't immediately notice a name or model # on them.
/ 2375 backhoe Leaky Control Valves #2
I’ve replaced every seal in my spool valves more than once in my backhoe. Search and you’ll find threads on the topic. Don’t use factory replacements. I’m sure there’s a Manual as I have for mine.
/ 2375 backhoe Leaky Control Valves #3
Search for the word Nimco and you’ll find the post
/ 2375 backhoe Leaky Control Valves #4
Talk to a good hydraulic shop, they can probably tell you how to improve the life of the seals either with better materials or maybe backup rings for the orings.
/ 2375 backhoe Leaky Control Valves #5
Backhoe Control Valve
/ 2375 backhoe Leaky Control Valves #6
They aren't rocket science; I have had mine apart a couple of times fixing leaks. Just start removing what appears to be leaking and go to NAPA or a hydraulic shop and match either o-rings or seals
/ 2375 backhoe Leaky Control Valves #7
For my nimco the sizes were a bit odd and took me a while to find the right size and compound and durometer.
2020 Ford F-53 Thor A.C.E 32.3 33.5ft Class A Mobile Home (A64557)
2020 Ford F-53...
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
