Mowing 2350 cutting height control dial
/ 2350 cutting height control dial #1
sprice930
BRANCHBURG
Kubota BX 2350
I just got a used BX 2350. It only had 10 hours on and in pristine condition. I turned the cutting height dial to top and now it wont move. Not sure if there is something I should be doing to allow it to move. Motor on...revs up but wont move. Is there a lock Im missing? thanks
/ 2350 cutting height control dial #2
Rev the motor slightly. Raise the deck as far as possible with the 3 point hitch control lever. Then the knob should turn. If that doesn't work, try lifting on the deck while trying to turn the knob.
/ 2350 cutting height control dial #3
I assume the 50 seriers uses the same type of stepped cam that the 30 series uses but I don't know that for a fact. If the mower is resting on the cam, I doubt you'll be able to turn it. Try lifting it as others suggested.
Tried what everyone suggested and no luck. Going to dealer Monday and see what they have to say. Thanks for everyone's help
UNUSED WOLVERINE QUICK COUPLER 3 (A64281)
UNUSED WOLVERINE...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
HI-PRO PTO PUMP (A64280)
HI-PRO PTO PUMP...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2016 Nissan Sentra Sedan (A61574)
2016 Nissan Sentra...
