2320 mmm & clearance
/ 2320 mmm & clearance #1
unreconstructed
Platinum Member
West Texas
JD 5325 JD 5203 JD 2320 LT 133
Just read the thread about clearance problems with JD belly mowers. Are there any clearance issues with a MMM on the 2320? Thanks for input--hoping to get a 2320 this year or next.
/ 2320 mmm & clearance #2
What do you mean by clearance issues?
See the thread about 5 below this one RE: Use care when buying a JD belly mower---he's talkiing about mower clearance and getting stuck in uneven terrain.
/ 2320 mmm & clearance #4
Overall, I feel the deck in it's lift height and ability to take on and off is outstanding. Also, I find the mow quality to be very good. However, I assume you are asking about the wheels/gouging into the turf? Personally, I have not experienced this, but I do run my "wheels on the four post" a bit higher than recommended, so you will get a little uneven cut if you approach a hill side ways, but I have yet to get the wheel in the correct position using this setting and it tends to line-up in the correct position before this happens. :D
/ 2320 mmm & clearance #5
No clearance issues yet with my 62D mmm. Does a nice job on my yard and I have not had the gouging problem yet either.
1991 Yamaha 130hp 2-Stroke Outboard Boat Motor (A66738)
1991 Yamaha 130hp...
2006 Wells Cargo CV63627 T/A 36ft. Enclosed Command Center Trailer (A66736)
2006 Wells Cargo...
PORTA POTTY (A68842)
16 Pipe Squeezer (A67714)
16 Pipe Squeezer...
PORTA POTTY (A67714)
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
